Question about Zebra Z4Mplus Label Printer
Labels enlarged I just ordered a new thermal print head for the zebra z4mplus and when i try to print out labels the text is jumbo. i then put on the old thermal print head and it works just fine. i've calibrated it and everything. i already ordered 2 new print heads and they don't seem to work.
  • Zebra Expert
  • 285 Answers
If they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Posted on May 05, 2008
  • 38 Answers
You likely ordered the incorrect resolution printheads.
You must replace printheads with the same resolution printhead as the printer was intended for.
Depending on the exxact model, available resoltions would have been 152, 203 or 300 dpi.
Steve Weinrich
LazerTek, LLC
Posted on Mar 30, 2008
When I send a print job to my Z4MPlus label printer, the label prints but without any ink on it. It is set to Direct-Thermal. What else should I be looing for to correct this issue?
Hi, you can have 3 scenarios here, the print head is faulty, mainboard faulty or darkness set to low, please reset printer to factory default without any lpt/com/usb/network cables connected, turn off and on. try to run Pause test ( turn on printer with pause button pressed for 5 sec and release it)
Feb 21, 2015 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
I created a new label layout in Filemaker pro to print a 4" x 6" label. When I print this label on the Zebra LP 2844 printer it prints fine. If I try to print it on the Z4MPlus it enlarges the print and...
The easiest solution would be to create a new label layout in FileMaker specific for that printer that can be used when printing to that printer which would solve that problem.
The issue with the size being enlarged is most likely with the printer driver and not the FileMaker software so that is where I would look around to see if there is a scaling setting, or some other setting that needs to be corrected in the driver/page setup area for that printer.
I hope I've done a good job answering your question. I am a FileMaker 7 expert (and 8, 9, and 10 as well); if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Aug 13, 2009 | Zebra Z4Mplus Label Printer
Change label size
Turn the power off. Remove old stock. Load new stock. Turn power on. Restart your program. Form size is software controlled from your form settings downloaded into the printer before your print. Make sure you restart your software to reload them.
Sep 03, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Ribbon wrinkles when printing barcodes
This is usually caused by temperature of the thermal print head. This is found in the printing preferences of the printer.
May 22, 2008 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Zebra Thermal 2844 prints text poorly
I found this information in the user manual:
Let the print head to cool for one minute, then use a new
cleaning pen to swab the print elements (the thin gray
line on the print head) from end to end. NOTE: You do
not have to turn off the printer to do this.
If print quality remains poor after cleaning, try the
Save-a-Print Head cleaning film to remove buildup
without damaging the print head. Call your authorized
reseller for more information.
Mar 31, 2008 | Zebra LP 2844 Thermal Printer
Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Dec 12, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
733 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
