Question about Intel Motherboard
Motherboard problem if i turn on my computer no beep nor display in monitor, i cleaned the memory and replace it but nothings happen...please help me... thanks ahead..
  • jayson barcelo
    jayson barcelo Mar 12, 2008
    asus pentium 4
  • jayson barcelo
    jayson barcelo Mar 14, 2008
    no beeps at all.... but when last tym i start it workz.. when i connect the keyboard it makes noisy sound i turn off then when i start it again nothings happen...pls help me
  • 25 Answers
Which mother board u r useing
Posted on Mar 11, 2008
  • kiran kiran Mar 12, 2008
    after removing the ram can u hear the beep sound
    if sound comes its ok
    if dosent come take to the nearest service centre
    (some regulators may be bad check it )
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
My lcd monitor AL1717 has initial blinkig &there is no display,after some times it works properly,what is problem.
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Apr 01, 2011 | Acer AL1717 17" LCD Monitor
When I turn my monitor on, the green power button comes on and then turns to amber. Nothing will display. What should I try
You need to check your video card. Check if it is still ok and functioning properly. You can also try checking your memory card. that are the two pieces usually causes that problem. Try this :
1. Double check the cable that connects the monitor and video card. Remove the connection of your monitor to your CPU (the video card cable is what i mean) then turn on your monitor. If the monitor displays a message like this " Check signal cable" it means it is working fine and there is a problem in your CPU.
2. This step is just for PC that are using PCIE or AGP video card,not built in there motherboard. Remove your video card if you have a PCIE or AGP video card, using an eraser (pencil eraser) you can clean the connectors of your video card (the coppers that is use to connect it to motherboard).
3. Try to remove your memory card. And the same as what you do in your video card, use an eraser to clean up the copper connector of your memory.
4. Put it all back in place. Make sure it is properly connected. Then turn on your computer.
If your monitor is still not working, you may use an internal speaker so that you can check if there is a problem in your motherboard.
If you don't know the meaning of the beeps try to read my tips and tricks i have the beep codes there..
Feb 27, 2010 | Computers & Internet
My computer system on power but mother on fun is run but no display
Check the display connection between the computer and your monitor, if its ok and still nothing happens then open your computer casing and then find the bios jumper settings, read the motherboard manual for it so that you can find it easily and then reset the bios, once reset, turn-on again your computer but if nothing happen again, do this solution: remove the memory stick of inserted in the motherboard and then clean the pins with the eraser of a pencil and then insert it back. Hope this could help,
Oct 25, 2009 | Computers & Internet
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
Turn on power nothing on my monitor, black ...
you semm have replaced any component in your motherboard eccept two, monitor and motherboard itself. try to put your new component in similar mother board begining with cpu ram vga, and put in output in same monitor (you must be hure that second motherboard is working) if nothing is coming try second monitor for output, if nothing is coming and have maybe beeps, one of your component that you have puted is defektive so try to replace them one by one. is not necesary to buy new component just try in other friend eith his parts afterthat if you finded defekyive component replace it in *********** board, (or if *********** board is defektive you must replace him, or monitor too if the problem is in monitor)
Apr 06, 2009 | Computers & Internet
PC beeping, monitor will not display
we have different sound we can hear in cases of hardware problem, once the video card has loose contact it also beep continously, a beep sound also occurs when the ram(memory card) loose contact, one beep sound when it boot clearly it proceeds as go signal going to operating system. if you are using an upgraded video card remove temporarily and use the on-board from your motherboard. in case that it won't boot and still you hear a beep, beep ,sound then, switch-off the power take out the memory card clean the contact points(bronze color) with pencil eraser, make sure that no remaining residues of eraser remained before you install to the slot. i hope that this solves your problem
Dec 01, 2007 | Computers & Internet
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
