Question about Andis Outliner II Hair Trimmer
Clippers not working
My clippers will not work after being dropped. i have stripped them completely down and have tried to realign them. they still do not cycle after all of this. what is the problem and how do correct it? thank you in advance.
  • 62 Answers
From the picture above it looks like you have an Andis Outliner. If that is the model you have please send it to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177. We will be able to repair the unit for you. If you would like to speak to a customer service rep first please call 1-800-558-9441.
Thank you,
Posted on Jul 21, 2008
Where does oil go for maintenance on clipper set
You'll want to apply some of the oil on the outside of the blades and if possible - detach (the way you would when you clean your clippers) and put a few drops of oil where the spinning rotor from the rotor goes into the bottom piece with the blades of your clippers. When you run out of what they give you - Try INOX - it's a completely non-toxic machine grade oil. Available through Ace Hardware or you can google the product name: MX3. INOX - MX3. Ask for it in the 60ml needle bottle. Hope this helped.
Aug 12, 2014 | Health & Beauty
My Andis excel 5 speed clippers will not turn on
Try the fuse in the plug first then try to move the cable where it enters the clippers it may just be a faulty cable.
Otherwise it will need stripping apart and testing, Sorry
Jul 10, 2014 | Andis Excel Variable 5-speed Pet Clipper
The lens are stuck out and the camera seem like its coming on but doesnt...Its a DSC-W170 Model
Take your camera and carefully look at the lens side of it. Does the lens look slightly out of center. Sort of pointing very slightly the wrong way. If it is you've given the lens a knock while it's been extended and put the complete lens barrel out of alignment. Please don't try what I've seen touted around the Net and bash the camera lens down on a table, this will make the whole thing completely unusable. The camera needs stripping down completely and the lens either realigned or worse, completely replaced.
The other problem it could be is a piece of grit or sand jammed between the lens elements or the lens and the camera body. Again a strip down job to free the jam.
Just make sure the batteries are at full charge and in good condition if they are getting a bit old try a brand new set of High quality alkalines and see if things start moving then. Quite often the camera may switch on but simply doesn't have enough power to drive the lens. Try the batteries first, you could save a packet.
Apr 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
My Andis Masters
tention is probably to tight, or blade needs to be realigned
Mar 11, 2009 | Andis Outliner II Hair Trimmer
Wahl hair clippers
lol This is unfortunate! I set these day in, day out, you have the right idea. Use the lever to push the cutter all the way forward, then push the comb down using your work surface, then use you free hand to tighten the screws. If your clipper is in factory condition this will have aligned them perfect. Give up? May or may not be wiorth it for you but try www.sheareaseltd.com Get postage details there, send your clipper to them (I work for them), pay the postage for them to get there, put a note in your box to Ash, asking me to align your blades, and I'll sort it for you but I'd have to charge return postage at £5!
Hope this helps!
Nov 11, 2008 | Wahl Magic Clip Clippers Hair Trimmer
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Andis Outliner II Hair Trimmer Logo
298 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
