Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi vs-50603 removing screen for cleaning
I read other posts looks good,but when removed speaker grill a sticker saying caution remove relay before removing screen. Fit screen so relay connector will not enter the rear of screen. Could anyone make this simple,tv looks good just want to clean.Dont need a repair.Waiting for prices to fall more on new TVs Thank You Don
  • 934 Answers
You were in the right place going at it from the front. After removing the grill the bottom edge of the screen has a series of screws holding the lower edging down. Remove the screws and gently but firmly work the sides of the screen frame up to unlatch the top. When you have the screen/frame in your hand just be careful not to go to far with it - wires attaching the panel controls are still attached and don't have a lot of extra length.
Clean the cans, mirror and reverse area of the lenticular screen and re-assemble.
Posted on Mar 13, 2008
Remove screen on Mitsubishi VS-5003R to clean the inside
screen unit is removed from front--remove speaker grill and some screws at bottom of screen and it lifts up and off.
Jun 05, 2012 | Televison & Video
Relay Connector on Mitsubishi TV
IF IT IS A WS-55511 what you are reading is with the speaker grill removed--there will be one or two sets of wires coming from the front keyboard--before you remove the entire screen assembly you need to follow them to the right and unplug both plugs.
The screen assembly will have about 5 screws at the bottom edge--with both plugs free and the screws removed you pull up and lift the screen about 4 inches and pull it off--if you have questions ask before you attempt to remove the screen unit--tell me also why you want to remove it.
If this has helped you rate this solution as I do this here for free.
Dec 12, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
I am trying to remove the screen on my Mitsubishi VS-4561 rear projection tv to clean it, how do I remove it? I know it slides up, anyone have a manual???
For my VS-45607 I had to first take off the speaker grill. Then there is a panel just below the screen that can be removed with screws; I removed this just for wire clearance. Then there are a few screws that are along the bottom of the screen that you take off and you should be able to slide the screen up and off. Good luck.
Dec 02, 2008 | Mitsubishi VS-45607 45" Rear Projection...
I would highly suspect that the TV's signal board has CRT Coolant (fluid) on it. Check closely and remove/clean with acetone. Good Luck, big IRISH.
Aug 30, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi vs-50603 no remote.what is code
Good Day, ariley1604;
Please contact comcast, and look into U- VERSE.
Aug 21, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Repair help
Good Day, limao247;
Your TV may fluid on the PCB's. Remove the speaker grill, the small panel and look closely for fluid on the boards towards the front. Always unplug the TV for your SAFETY. If you find fluid clean board with acetone. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
MITSU VS - 50603
Good Day, wecalvin;
Suspect fluid on the PCB's.To find suspected liquid on the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Aug 05, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
