Tv continues to shut off, and is giving us a buld warning light.Have had the bulb replaced 2 times in the last month.The ballast was checked and found to be o.k. Having problems with the extended warrenty people saying its a bad bulb again
  • 31 Answers
I work for a company that is factory authorized for 20+ manufactures I am sorry but a didn't see your brand and model # if I can get that I can research it for your and see what may be your problem. Sounds like something is blowing your bulb or they are not putting the correct value/wattage bulb in when changed. Let me know
Posted on Mar 11, 2008
How to tell if ballast is bad on samsung dlp tv
It is a common practice that the ballast to repalce along with new bulb. There is no way to check the internal winding short of ballast. Repalce both at the same time. If ballast has any damage, it will surely ruin the bulb too.
Jun 04, 2012 | Samsung HL50A650 50 in. TV
I had to change my bulb about 6 months ago and now i'm having the same problem. i checked the bulb to make sure it was still intact and indeed it was. i'm wondering if there is some kind of switch to...
Ur tv probally also have the board call the Ballast board is also dead beside the projection lamp was replaced before.This board call the Ballast board job is to help to ignite the projection lamp.About an hour before the Super Bowl.Unplug,replug the tv back about an hour later for the tv for the Ballast board might have some juice left to ignite to light up for projection lamp for the last time to have tv picture to the to watch the Super Bowl.Must replaced the Ballast board.
Feb 05, 2011 | Toshiba 50HM67 50" HDTV
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
I have a Samsung HLT5075s. Last Sunday the Tv
Not the light engine. But it could be the power supply. I've seen a few than pass "dirt" power to the ballast and damage it. Have a peek at the ballast, there's a big 47uf, 450v capacitor on it. If it is swollen, it's a dead give away. You need both. I hope this was helpful.
Mar 30, 2010 | Samsung HLT-5075S Television
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I have the 50" SXRD XBR1 grand Wega; This has been a great set for 3+ yrs. A flashing red light promted me to replace my original buld (this site). I now still have a flashing red "power" light, shuts off...
Its the fan that cools the bulb. Try turning on the tv and look at the fan to the rear of the bulb. If the fan is not spinning that is your prblem. The tv has a safety switch that will cut off the tv if the bulb gets too hot. I was able to tap my fan with a pencil and get it spinning, but that is just a temperary fix. After a while, you will find the fan will stop working all together and it will need to be replaced.
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Buzzing sound, resets 8 times, and then turns off. Bulb replaced
Actually ballasts run between 60-80 dlls. It does sound like you doi have a ballast issue, everytime a TV resets the ballast is the issue. Go to discountdashmerchantdotcom you'll see the ballast prices. Plus they also have free troublehsoot.
Aug 25, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
PT 50LC13-50 Panasonic TV
Going through bulbs that quickly would indicate to me a problem with the ballast or smps (switch mode power supply). It's not something you want to just run out and replace (expensive).. Call a reputable shop and tell them what you're experiencing.
I do know that they should check the value of C1330 in ballast circuit. If it is a .22uf, There is an upgrade kit available for it, panasonic p/n# LSUC0022
Nov 05, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
