Question about Samsung ML 4600 Laser Printer
Samsung ML-3561N Remote access for count
I have ML-3561 N printer , Kindly advise me how I will be able to check How many pages printed , What is the status of toner . Page Counts etc Remotely.( Through Networ)
  • Rafique Mannasaheb Mar 11, 2008
    There is one software from samsung SyncThru™ Web Admin Service Does it will help me.
    Regards
  • Anonymous Mar 19, 2014
    Password per modifiche
    Master:
  • 377 Answers
Hi mate, I am telling this to you in private. If you don't know a solution you are welcome in contributing with good questions or posting a manual or whatever is helpful, but please dont just copy and paste misleading info. This is making customer not coming back and getting all us a negative feedback.I am sure you will understand.
Many thanks
Posted on Mar 19, 2008
Tip
Solution to red light after refill Samsung ML 1540
Samsung printers such as ML 1640,ML 2245 and SCX 4300 have a toner page count embedded in their firmware. This is the reason that once you refill your toner after it has run out,the printer still doesnt print and says toner is exhausted. After you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here. ML 1640 Ml 2245 and SCX 4300 are not available on Samsung support site. You will need to google it and you may find it in torrents.
run it and it will reset your toner count to 0...you have to do this everytime you refill your toner.
Another solution is to open the backside of ML 1640 and ML 2245,locate the chip 93c66 and short pin numbers 1 and 4 and turn on the printer for a second.It only works in some cases though.
on Sep 01, 2009 | Samsung ML-1640 Monochrome Laser Printer
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
Solutions for "engine fuser low
The "fuser" should heat-up to its operating temperature to "melt" the dry toner-ink onto the paper.
If it is not heating up, then each page you print and brush with your fingers will remove the toner.
So, replace the fuser, or get it professionally replaced.
May 15, 2011 | Samsung ML-3561N Laser Printer
My Samsung ML-3561ND is double-printing, usually below the actual print, but sometimes to the right. No apparent reason, as only about 5,000 pages have been printed. Samsung is no help & want me to...
This could be the issue with the optics inside the printer. It is recommended that you send it back for repair/ replacement as fixing the optics and their correct alignment is sometime very tricky even for professionals.
Good Luck!
CreativeTECH
Dec 22, 2010 | Samsung ML-3561N Laser Printer
My ML-3561 clicks on & off when I turn it on
Common issue with Samsung Laser Printers. Your power supply is failing or in your case has basically failed. There are a series of capacitors on the power supply that go bad from heat and begin to fail. When this happens the machine usually begins "rebooting" after a print job, turns on and off randomly and eventually will not power on at all. Good news is it is a fairly simple repair. The power supply must be removed and the bad capacitors replaced. Parts are less than $25.00. Labor I would charge would be around $75.00 so a total of around $100. The trouble is going to be finding someone locally that can or will do the job. You can try checking your local yellow pages for printer repair places and see if they can help you.
Aug 25, 2010 | Samsung ML-3561N Laser Printer
How do I do a total page count on a Samsung ML-1710 printer?
On the menu selection, you can print a config page that will give you this information
Jun 18, 2010 | Samsung ML 1710 Laser Printer
How can i do 0 for ml-1640 page count ,and want to resetpagecount
You have to flash the printer with the fixed firmware and it will never ask you again for a new toner cartridge :) it is a 1 minute job for me and i charge my Local customers 10 Euro mostly because it has to be done just once and then you just refill the cartridge without doing anything else ( this is just an explanation - i don't want your money)
Jun 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
ML-1640 is cannot print.
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Aug 31, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML 4600 Laser Printer Logo
77 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
