Question about Dell Dimension 8200 PC Desktop
Hard drive replacement w/system restore disc
Our dell dimension 8200 original hard drive is on the outs. If I replace the hard drive with a new one, will the xp restore disc that dell gave me work on the new hard drive? Not sure what I should actually be doing to get the cd drive to boot with a new hard drive. Actually, I'm not sure exactly what I need to be doing, or what the steps are I should take.
  • 139 Answers
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Posted on Mar 11, 2008
Why does my dimension 8200 dell desktop say "strike f1 to retry boot, f2 for setup utility"
Rduy Cruz,
This error message references that your system Primary hard drive is not being Detected in the system. You can press F2 to enter the setup to see if the hard drive is even being seen. If not, exit out and shutdown the system. Unplug the power cable and open the computer to reseat the hard drive cables at the hard drive and at the motherboard connection. If that does not resolve the issue you may need to replace the hard drive IDE cable.If all this does not work you may need to replace the hard drive. Please post back if this does not resolve the issue.Below is a link to your online manual for your computer.
Dimension 8200 Online Manual
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 24, 2013 | Dell Dimension 8200 PC Desktop
Have used dell dimension 2400 hard drive died replaced it now it only goes to boot device menu or black screen with blinking cursor
You will a full blown version of whatever software you want to install. Also try using the F8 key during bootup. See if the computer will boot up into Safe Mode. You should be able to made System restore disks from there if it will get that far.
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
Hard drive continue to clicks, message to hit F2 to configure.
If you have a clicking hard drive and the system gives a F2 to continue but will not boot, most likely you have a hard drive failure.
Boot to the BIOS (F2 at boot) reset the defaults and save, see if anything changes.
Most likely, you will be replacing the drive
Jan 30, 2010 | Dell Dimension 4600 PC Desktop
Having Trouble Reinstalling XP on my Dell Dimension 3000
Here's what I would do. Download and burn any Linux disk. Install Linux and delete all partitions while doing so. After that, initiate the Windows XP installation and see if that works.
This will take care of two things:
If you can install Linux, then the hard drive is good and the partition that was previously on there will be deleted (I suspect the partition is locked which can be caused by a virus or the software used to scrub hard drive).
Check your CDs for Windows (for scratches) or it could be your actual CD drive is out (laser) which would make the installation fail. If the CDrom cannot read the disk, it locks up like that during installation...even if it read before.
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
New hard drive choices
Hello, Bob!
Seeing as I am a 6 year veteran of Dell Tech Support, I should be able to help you out, no problem.
One thing that I would like to let you know is this: according to Dell Support Policy, you ARE allowed to put a non-Dell-branded hard drive in your computer. However, if Dell Support deams that this non-Dell hdd has caused another Dell component to fail, they will not replace the defective product. BUT, since it is HIGHLY unlikely that a non-Dell hdd would actually cause any other failure, feel free to purchase a non-Dell hdd. (I often times suggested that customers take this route because unless you're purchasing a refurbished Dell product, you're only paying for the Dell name.)
There really are no limitations to what size hdd you can install in your computer. Of course, a larger hdd will take more time to process information (Basically, there's more surface area to scan when your computer is searching for a specific piece of information.). Your main thing will be determining if you have an IDE hdd or a SATA hdd.
The Dell Tech website CAN be your friend ( From there, you can view original configuration and even available upgrades simply by entering your service tag (Usually found toward the back of your computer, on a black sticker with white text. It should list your service tag, an alpha-numeric value, and express service code, an all-numeric value).
If I were in your position, I would most likely not go over a 160g or 200g hard drive... simply to keep decent performance.
Hope I helped!
Oct 29, 2008 | Dell Dimension 8200 PC Desktop
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Dell 8200
wow..that's bizarre..
I'm assuming you had to format and repartition the drive, right?
when you boot to windows, press F2, and go to set up to make sure that it's looking for the new drive.
Feb 27, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
270 people viewed this question
Alun Cox
