Question about Samsung CLX 3160fn All-In-One Printer
Networking a printer on a Netgear Router
I also have a Samsung 3160fn and I can not figure out how to get it working on my network. I currently have it plugged into the router and I can not get my laptop to see it. I have been at it all day and can't find any help online either. I have used the users guide and the Network printer guide but no luck.
Help!
Jim
  • Anonymous Apr 01, 2008
    When I plug the ethernet cable connected to the printer, the computer does not detect the printer through there. It prints fine via the usb, but it does not even see the printer. I've configured the IP's and everything else in the printer and computer, but it is still not detected. Please Help.
  • 18 Answers
This is what I did to mine to keep it from conflicting with my HP laserjet. On the printer - Go to menu> network> TCP/IP> set that to Static then hit ok and go to TCP/IP Address, enter the TCP/IP address you want to use. I used 192.168.1.104. You always have to use the 192.168.1. the last three digits have to be over 100 and under 149. Go to Printer/Faxes and find the CLX3160FN. Right click on it, click on properties and then click on the Ports Tab. Go to where the check mark is. It should say Standard TCP/IP port and the name Samsung CLX-3160 FN. Highlight it and click on Configure Port. Make sure the address there matches the Static TCP/IP address you set in the printer. Good luck.
Posted on Aug 18, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Did you cofigure the IP address on the printer?You need to configure the IP address before add printer.
Posted on Mar 14, 2008
2 Suggested Answers
  • 18 Answers
SOURCE: Samsung 3160fn network question
You have to have the software set up on the laptop to be able to print from it. Also when you install the software make sure the laptop is hardwired to the router. I have found that if I try to set it wirelessly it won't work. I set it up hardwired to the router then it found it wirelessly. So make it short. Set up the printer on your laptop as though the laptop is actually a desktop. Then it will be able to find the printer wirelessly.
Also make sure that when you check the Network settings on the printer you have the same TCP/IP address for the printer in the PC and Laptops. I posted a long explanation on another post in this forum. You can take a look and find as a solution to someones network problem. The way I do it is to set up the router on the computer first. Hook up the internet to the router. Then set up all the other PCs on the router. Then hook up the printer to the router and turn it on. Then run the installation software for the Samsung and make sure you tell it the printer is set up on a network. See if the software can automatically detect the printer (it should). Pick your printer from the list of found devices and install it. It should work fine then. Also make sure that the Windows firewall is turned off when you do that or have it set to allow local network traffic. Good luck.
Posted on Aug 20, 2008
MFC 465cn, how do i access it wireless?
You must first set it up, and then connect to it as a "Networked Printer" and then hook up;
All Drivers must be installed.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Set it up as above tutorial.
Apr 04, 2010 | Brother Multi-Function Center MFC-240C...
I need help networking a brother hl5250dn on a netgear router. It worked fine for me for about 1.5 years networked on a dlink router, and when I changed to this netgear, this feature started. After...
sounds like the printer is going on standbye mode is there setting in the options of your printer for standbye mode or is your central computer on stand bye mode to me sound like you need to check your setting in options of windows with the computer main.
Jan 27, 2010 | Brother HL 5250DN Laser Printer
I have an Apple Mac connected to Netgear router. Partner has Del laptop which she wants connected via my router. Bought D Link 1005D switch but don't know how to connect both of us thru it. Do I need set...
What type of Netgear Router you are using?
If you have more than one ethernet ports to your Netgear Router, then connect your switch with a patch cable to the Router. Switch on it and check.
So that can share the resourses.
Dec 28, 2009 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
How to get a print by using wireless function
Share Your Printer on a Home Network· Navigate to the Control Panel and click on"Printers and Other Hardware."
· Click the printer you want to share in thePrinters and Faxes folder. Click on "Share this Printer" in the TasksPane or right-click on the printer and select "Properties."
· Open the Sharing tab and click on "Sharethis Printer." Enter the name of the shared printer and click"OK."
· Use the shared printer with any computer on thenetwork by navigating to Control Panel > Printer and Other Hardware.
· Click "Add a Printer" and browse forthe network printer you just shared.
Connect the Printer Directly to the Network.· Plug the printer directly into the network hubor router.
· Follow the instructions for setting up theprinter for networking provided by the printer manufacturer.
· Click "Add a Printer" and browse forthe network printer.
Dec 17, 2009 | Samsung CLX 3160fn All-In-One Printer
No connection
the printer needs an IP address from dhcp server or in other words, the router. the switch just acts as a kind of repeater on network segment.
Jul 08, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Mar 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Netgear FS105 Switch is not fowarding ports properly.
Does your modem have a built in router or do you have a router in your network. The switch needs no changes that's all it is a switch it will allow computers to talk and share fine, if you want to use it for internet you will need to connect it to a router first or use one of your computers as the router and let it share the connection. since you disabled DHCP on your router I am assuming you have a router. all you need is to connect the switch to the router, the connect the computers to the switch and all should work.
Dec 24, 2007 | NetGear FS105 5x10/100 Mbps Networking...
HpC6180
Hi, Based on your post/description, I will assume that your printer is connected to your network by either by WiFi or Ethernet and not by USB to a particular PC. If it is USB connected to a PC, then it should still work since it is not physically connected to the router. Since your "Internet radio" was just recently upgraded, it is possible that the networking configurations have been changed. Having said that, it is perhaps required that you likewise changed the networking configuration of the C6180 to conform with the new settings. Pls post back with information on: 1. How is the C6180 connected; by LAN to your router or by WiFi? 2. What is your new/current networking configurations (IP add, Subnet Mask, Default Gateway, DNS, Network/Workgroup name)? 3. Do you still have the original CD installer/driver, the user's manual and the quick installation guide? 4. Do you still have the original USB cable that came with the printer? Alternately, you can checkout the installation guide at the HP website (http://h10025.www1.hp.com) or go through the installation procedure again using the CD that came with the printer (of course you must initially uninstall the HP C6180). Hope this be of some help/idea. Pls post back with additional information/details so we can figure things out. Good luck and kind regards.
Oct 01, 2007 | HP Photosmart C6180 All-In-One InkJet...
Netgear fsm7326p L3
Any new additions to the router table? Since the two segments are probably outside of your subnet mask, each connection has to check the router table to figure out how to get there... so maybe the router table is getting super long, and it's timing out before it hits the right line. Could also be Is there a process that's occuring simultaneously that could be be taking a lot of bandwidth, such as online backups, etc.
Sep 11, 2007 | NetGear FSM7326P Networking Switch
Samsung CLX 3160fn All-In-One Printer Logo
332 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
