Question about HP PSC 2410 All-In-One InkJet Printer
Scanner not working properly - HP PSC 2410 All-In-One InkJet Printer
  • Anonymous Apr 17, 2009
    It is the exact problem, I called HP, they charged me $15 for a new loading disc, but alas, the same thing, thanks HP.
Scanner not working properly. Will print OK from computer but will not scan so you can read original
Posted on Mar 30, 2008
How to reset my Uniden BC75XLT Bearcat Scanner .
Resetting the Scanner
If the scanner's display locks up or stops operating properly,
you might need to reset the scanner.
CAUTION: This procedure clears all the information
you have stored in the scanner. Before you reset
the scanner, try turning it off and back on to see if
it begins working properly. Reset the scanner only
when you are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the scanner.
It takes about 3 seconds to initialize and CLEAr appears.
Jul 08, 2014 | Uniden Bearcat BC75XLT Police Scanner
Radio shack pro-96 scanner screen blinks and loss of audio
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
Hp officejet j5508 all in one scanner not working
possible solution
is printing is working?
use exact software for printer for proper scanner working go to HP site and download new latest version softeare and install proper instruction given by HP then try
May 16, 2012 | Office Equipment & Supplies
Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
Do the following:
Uninstall the scanner from your computer
Restart
Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
Restart again
And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
May 07, 2009 | Office Equipment & Supplies
I have a uniden ubc73xlt handheld scanner,can't program channels, keeps saying locked out, have tried to unlock as per instructions but not unlocking.
Try a master rest:
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Feb 22, 2009 | Uniden BC72XLT Handheld Scanner
Radio Shack PRO-91 scanner keypad doesn't work
Try a master reset. You will lose all of your current programming but it resets the unit back to its original state when you purchased it. here are the directions from page 53 in your manual.
and CLEAr appears.
elijam1
http://www.scannermaster.com/?Click=37131
Dec 25, 2008 | Uniden BC72XLT Handheld Scanner
Software can not find Scanner
ok connect your scanner in other usb port also check that all usb proper working.
then try to change cable.
may be your xp sp3 virsion not detect your scanner install proper driver for that.
Nov 18, 2008 | HP Scanjet 4200c Flatbed Scanner
Scaner is not working of hp3055 color laserjet printer
Step 1:. Check Hardware Driver Installed Properly
- My Computer-Properties-Hardware-Device Manager
- If Yellow mark in printer and Scanner field, the Printer
driver not installed properly.
- So reinstall Printer Software
Step 2: If Scanner Option only not working,
- Go to Scanner Settings(Start-Programs.....)
- Choose Correct Scanner Name.
Or
- Press the Scanner button in hp 3055
- If Hardware driver was installed correctly, its automatically
deduct on your PC
Jul 02, 2008 | HP Color LaserJet 2600n Printer
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
HP PSC 2410 All-In-One InkJet Printer Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
