My Hotpoint HSS25GFPEWW side by side is staying warm (close to 48) on top of the fridge side and won't freeze anything on the top of the freezer side. Ironically, it is freezing anything I place in the bottom cripser area of the fridge. Ony the middle section of each side is cooling properly. I have paid repair guys to no avail! HELP!
There is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Testimonial: "Thank you Salde386 ... You guys ROCK!!!!! I took it apart and read through your information. The evaporation fan was messed up! Running awesome now!"
can you tell me what the tech did or found?sounds like the air isn't moving correctly like a problem with the evap fan or the damper control or you could have a refregerent leak?did they check the evap coil to see how the frost pattern was,if you remove the inside freezer wall and look at the coil it should be frosted up,if it's frosted only half way or 3/4 you could have a leak,it's tuff to say without being there,if you can tell me what the tech told you it would help,also how old is it and how much money will it cost to fix it with what you paid already,
