Question about Philips Smart 25TS54C 25" TV
Tv won't power on red LED blinks 4 times
I have a 27" Philips Mangnavox Smart Series 25tr19c225. I plug it in, push power, and the red power light blinks 4 times silently, and otherwise nothing, no power, picture, sound, nothing. Can I fix this?
  • Adamisskiing Mar 11, 2008
    The tv has been doing this for months. I wasn't around when it first went out.
  • Anonymous Mar 27, 2014
    tv not power up and red led blinking
    Genius:
  • 1,694 Answers
Clarification : Your set is a 25" ( 25 TR19 C 225 )......
1) In horiz drive circuit, check / replace bad 47mf / 25v capacitor
2)In same area, locate and replace bad transistors ....usually
a little over-heated in that area of PC board....look with magnifier
numbers are 327-25 = BC-328 and 337-25 = BC-338
3) Solder any / all bad connections...............................T.
Posted on Mar 11, 2008
  • Vista Electronics Mar 11, 2008
    If that doesn't fix it ,you probably have a vertical problem =
    Solder vertical output IC to start and let me know..........T.
  • Vista Electronics Mar 28, 2008
    Any progress on your tv repair ?..........................T.
    Brigadier General:
  • 3,614 Answers
Hello there,
You can fix it "but" are you familiar on servicing such like a TV unit..
Have any experince to troubleshoot and service the board and make some solder on the part..
If "YES".
I got this one information regarding on your Query on the top.
I'll post and paste here the direction where you can find the problem was really like there:
SOLUTION:
The steady blinking light means there is no specific code.
This is from Sony authorized repair said the double-side board (the one lying flat/horizontal just to the right of the vertical power supply board which has the fuses) has a burnt transistor (the one with the sizable heat sink on it, at the back left corner when looking at the board from the rear of the TV). It is blowing the (non-power supply) fuse.
Enjoy..
Best regards,
-microman
    Brigadier General:
  • 6,966 Answers
HI,
Was there any recent power interruption or a thunderstorm recently in your area?
  • Louie  Role
    Louie Role Mar 11, 2008
    Hi again,
    Copy your postback/reply.
    As most current model of TV units, blinking red light is an indicator of internal fault as sensed by the built-in diagnostics. Some models/versions of Philips-Magnavox are prone to surges or interruption in the power as well as static discharges along the powerline caused by a near lighting strikes.
    Let' try the easy one first. Pls try a reset on the unit by unplugging it from the mains for a couple of hours (preferably overnight). Thereafter give it a try. Pls try to check if your hear any faint clicking sound (relay) or smell any burning or electric arcing from the back.
    Should problem persist, further diagnosis and repairs of course would require familiarity with electronic components and circuitry, use of a DVM and a soldering iron plus access to a service manual or at the very least a schematic diagram.
    Should you feel comfortable doing a DIY, then pls post back.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
SOURCE:
I have a Philips TV model 32HFL5561V/27. Problem Will not turn on red light blinks 5 times and then flashes three times Then repeats
This code is for LED power supply failure, its common, there are two 47uf @ 100VDC capacitors in the supply line for the LED lamps those need to be replaced with 100uf @ 100VDC caps..This is another manufacturing error from not so good Chinese brand Funai that makes this TV
Mar 24, 2018 | Philips Televison & Video
My mangnavox tv model 26mf605w/17 power button flashes when I turn it on and the screen want light up
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jul 31, 2014 | Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
I have a Philips 42pf5321d/37 that won't turn on.
send me a email [email protected] and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
