Question about RCA Televison & Video
Rca doesn't honor their warranty.
I was told to send my RCA VCR player to ThompsonInc. at Socorro, Tx. and they would send me a new DCR8335 in exchange. I sent the player on 12/12/2007 and wrote ATTN: SR04192740 on the package as instructed. When I called Thompson at 1-877-805-0519, they told me to e-mail rca1800customersupport.com but when I did, there was no sight. Fae Stene
box 203, McVey Rd.
Sunburst, mt. 59482
hfstene@hotmail.com
techman
  • 3130 Answers
SOURCE: Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
Posted on Sep 27, 2006
SOURCE: DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Posted on Jul 19, 2007
DOREEN1
  • 51 Answers
SOURCE: DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Posted on Jan 25, 2008
  • 84 Answers
SOURCE: rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Posted on Feb 04, 2008
SOURCE: Universal Remote Code search
etec dvd 2258 player ... does anyone have the remote code for it?
Posted on Mar 14, 2008
Dvd/video copy player doesn't work
It will be far cheaper to replace the item with one year warranty than send it to RCA, factory rates start at $100.00 and up.
Jul 07, 2012 | RCA DRC8030N
No picture but sound on DVD player
hi..it maybe a RCA connection problem..it's better that
you don't remove the audio, try to re insert the video RCA
its color yellow...look also for yellow RCA port on the TV and connect the
RCA from your player...if still does not work why not use a new RCA jacks..
hope this help...please rate and vote..thanks
Feb 19, 2011 | RCA DRC6100N DVD Player/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Rca dvd player is not reading most disks
To ALL users of the RCA/Thomson DCR8335 VCR/DVD combo player/recorder.
NOTE: This unit is problematic and most likely, that is why is has been discontinued. I've have all the problems listed at this site and www.consumeraffiars.com. I would advise to stay away from RCA/Thomson and Audiovox (as I read online that Audiovox bought out RCA Audio/dvd products). They won't even honor the written warranty to repair the unit at a local RCA authorized facility. They are stating that repair parts are no longer available, and the only recourse they are offering is to exchange the unit with another problematic DCR8335 which is not accecptable in my opinion. They also want you to pay for the return shipping which is not cheap. If you push them to talk to a manager and refuse to pay the return S&H, they offer to give you a prepaid shipping label to pay for the return shipping. I refused to take the same unit as a replacement as I read online testimonials of others who did and encountered the same issues. We need to complain and have them offer a monetary refund so that we can purchase a comparable replacement unit of our choice after researching the product so we don't end up in a similar scenario.
Wishing you all the best with your resolutions pursuits...
Have a great day!!! :)
Jan 04, 2009 | RCA DRC8335
Rca vcr / dvd just stopped working
If the unit is only a few months old, it should still be under warranty. Return it to the place of purchase or at least call there to find out where to send it.
Dan
Sep 09, 2008 | RCA DRC8295N DVD Recorder/VCR
No lights
On the power supply unit it does have a fuse, look near where the 110 volt connects up to the board. It should be very close to this connection. The Fuse is a soldier type, small and white in color it is located very near the front of the playier. I don't think the problem is electronic but rather software issues. The software is really buggy on this unit and even the reset doesn't offer any help. I was told by RCA a $50 dollar fee would be the repair cost, plus the shipping to and from. I'm not putting another $50 dollars in something they should be able to make a fix and allow a free download to help correct the problems. It could be an electronic issue, I maybe wrong but it does appear more software! It might be, a reload of the original software would help, it could have corrupted through static or other possible causes. They don't offer that or any hope of it. Support for this unit is down right sloppy at best. Not impressed with this unit at all, my experience is with a 5 month old unit, because it was a gift they will not honor the warranty.
Sep 05, 2008 | RCA DRC8052N DVD Recorder
RCA Opal M4002A Need screen
I have an Opal 2GB mp3 player just like yours and I accidentaly busted the screen on it, so I e-mailed the RCA company, they e-mailed me back telling me that I voided the warranty, and I would have to send it back and pay 55 dollars to get a new one, because they don't sell the individual screens.
I hope this helps.
Apr 02, 2008 | RCA OPAL M4001 MP3 Player
RCA DRC8335 VHS / DVD player does not work
if it's new, send it back. it should still be under warranty.
Mar 27, 2008 | RCA DRC8335
M4008 Opal mp3 player error message
I went to the rca site and downloaded the firmware update. It told me how to reset the unit. You have to let it crash, then start it from the Start menu. Then you plug in your player while holding down the play button while it loads. It managed to get it running but I still can't add music.
Dec 27, 2007 | RCA OPAL M4001 MP3 Player
RCA dvd-vrc combo model DRC8320N
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
Jul 23, 2007 | RCA DRC8300N DVD Recorder/VCR
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
