Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
Canopus ADVC 110 converter box not working
The firewire was put in backwards - now the box won't work. There is power as the box heats up - but the lights won't come on. The Status bar turns red for a short time then goes off. The Digital In and Digital Out do NOT light up.
  • Anonymous Mar 11, 2008
    both
    Scholar:
  • 119 Answers
Plugging in the FireWire backward, especially if it's the 6-pin FireWire, will damage the unit's hardware. You need to contact technical support to arrange for repair.
Posted on Apr 05, 2008
I cannot get video from my VHS through my canopus 110 to my computer. The VCR works fine. It is attached as suggested. With my analog camcorder I have no problems.
I had this same problem. Took it back and got my money back. Was trying to use with iMovie. Was told I needed at least the ADVC300 (also known as Canopus). Not sure why, but the 300 did the trick. Could be other problems, though. Maybe your firewire is bad, or the port on the computer. Or the connectors you're using between the VCR and converter. I hope it isn't too late to exchange any of the equipment you bought. Usually it's 14 days for these things. Good luck! It is hard to pin down these problems!
Nov 02, 2011 | Canopus ADVC-110 A/D Converter...
How do I get the video out firewire option to become avilable with my canopus box?
You are found your advc video capture has rear and front cable connector so you can find this very simple.
Nov 28, 2009 | Canopus ADVC-110 (77010150100) Video...
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
May 07, 2008 | Canopus ADVC-110 A/D Converter...
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
ADVC-110 not working for me
iMovie or Final Cut Pro should work.
Sep 18, 2007 | Canopus ADVC-110 A/D Converter...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
537 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
