Question about Brother HL-2070N Laser Printer
PAPER JAMS CONSTANTLY
Our office owns 10 Brother 2070N printers. Two of us seem to have constant problems with the paper jamming. When I can finally pull it out it looks like an accordian.
In the past someone here made an inquiry and have been told several things. Change the drum, change the toner and finally be sure to use @ least 20# paper.
In less than a week I have changed my drum, toner AND ordered 10 reams of 24# paper. This printer STILL jams constantly. When I am closing the month there are some reports that will print only once. I cannot tell you how much data I have lost because of paper jams.
Furthermore, I see no reason why 20# paper shouldn't work perfectly.
Please offer a solution.
  • Jingalls Mar 11, 2008
    Thanks, there's nothing in there, one of the engineers here has checked that out at least twice.
    I'm sick of this printer.
    Thanks for trying.
  • 59 Answers
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Posted on Mar 11, 2008
Paper jams too often and for no apparent reason. This time tore paper and therefore unable to unjam!
To clear the paper jams always follow the instructions from the manufacturer, here is the support page from Brother website.
Also, sometimes when I get paper torn inside, I use a pair of long-nose pliers to remove it, but be careful not to damage any parts inside the printer.
If the printer is jamming constantly then that means you have a hardware issue in there. Look carefully where is usually jamming and see if you have a clip that stops the paper or a roller that's not pulling the paper and try to fix it or replace the faulty part.
Dec 02, 2010 | Brother HL-2040 Laser Printer
MFC-9840CDW Laser Printer: I have a Brother MFC-9840CDW laser printer it is o...
Wipe the paper feed rollers with a clean rag wetted with plain water. You can also replace the feed rollers, search for "paper feeding kit" for this printer. Should be $20 to $30.
May 18, 2010 | Brother MFC-9840CDW Laser Printer
Black is not printing but other colours are MFC 685
i was getting lots of paper jams with mine before the black stopped too
Jul 26, 2009 | Brother Multi-Function Center MFC-240C...
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Brother mfc 7420 constant paper jam
need a little more info on this. does the paper look like it catches on something? is there any nicks or anything on the lead edge?
razors
Jan 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jamming
tell me where it jams so that i may help you! brother tec
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
Paper jams, white streaks
Hi marge383
this problem occures from the sensor found in the outgoing of the paper just before the fuser, if you are not technition check all sensors.
hope this helpful for you,
thanks
Hamedo
Oct 02, 2008 | Brother HL-2070N Laser Printer
Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Jul 24, 2008 | Brother HL 5250DN Laser Printer
Brother HL-2070N Laser Printer Logo
411 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
