Question about Nolo Dealing with Problem Employees: A L (1260150SF)
Pen drive mp3 reader
I hanve a Poline digital portable mp3 reader. the mark is MB-529
Since a while I am not able to copy file on it. Initially when I plug it, as response to my attempt to copy files on it, the computer says that it is not fromatted.
I used the STUPDATERAPP to dowload the firmware, that was on the CD I got along with the pen drive. While doing this I ticked 'format data area'
Since then the computer failes to install it as drive. In addition it blocks the computer when I plug it.
I would like you help me to get it work again or shall I consideer that I lost it for ever?
Thnaks in advance
DF
  • DFatondji Mar 19, 2008
    To format it by clicking the the right key, I need the drive letter. If the drive letter appears it means that at least the computer recognize it. So far it is not the case. On the LCD of the mp3 I can see endless scrolling of the word 'READING'.
    Thanks for your help but we have not succeeded yet.
    Regards
    DFatondji
    Problem Solver:
  • 7 Answers
You Better Format It Again From The Right Click Menu Or Better From Ms-Dos..
Posted on Mar 19, 2008
  • Alex Jose Mar 20, 2008
    then the firmware of the pen drive must be gone... thats why its is not recognized by your pc. if the firmware is deleted then i my knowledge there is no solution.
I HAVE 4 GB I-BALL PEN DRIVE. AFTER COPYING FEW FILES IT STARTED SHOWING "WRITE PROTECTED". NOW IT'S IMPOSSIBLE FOR ME TO COPY OR TO REMOVE ANY FOLDER FROM IT. HOW TO REMOVE WRITE PROTECTION?...
insert pen drive in safe mode. opern RUN from START menu. type : "FORMAT <drive letter>: /X /FS:NTFS" without quotes and press enter. drive letter is the pen drive.
Feb 24, 2011 | iLO (2 GB) MP3 Player
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
How can irepair my pendrive memory . my pendrive memory is 4 gb but the computer show it as 95.3 MB
Copy all the files from the pen-drive to your 'C:' drive.
Open "My Computer".
Right-mouse click on the icon for the pen-drive.
Click "Format".
Choose "quick-format".
When the "format" completes, it should show the full size.
Copy all the files back onto the pen-drive.
Oct 13, 2010 | Computers & Internet
On inserting the pen drive,its showing that no disk is inserted into H drive.And on seeing the properties of the pen drive,its showing Zero MB free and Zero MB in use.Its not even being formatted or...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jul 07, 2009 | Pen Drive IVO MP3 Player
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
The media is write protected
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Sep 06, 2008 | iLO (2 GB) MP3 Player
How to load music to mp3 from computer
First you connect the mp3 to the pc, it will show you as pen drive & you can copy the files to the mp3 from there you can use that one.
Feb 15, 2008 | iLO (2 GB) MP3 Player
Autorun not executing
every mp3 player has some space taken up by the native software, so it always shows less than advertised
Jul 10, 2007 | Transcend T.sonic 610 MP3 Player
Problem in pen drive/mp3 player capacity
when you hook it up to the puter, go into My computer right click on the removable drive then click on explore disc and see what oter types of files are taking up the extra memory as if there are none then the drive has bad memory cells.
Apr 28, 2006 | Sony NW-E405 MP3 Player
Nolo Dealing with Problem Employees: A L (1260150SF) Logo
70 people viewed this question
Top Nolo Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Andrew Taylor
Andrew Taylor
richie46
Are you a Nolo Computer and Internet Expert? Answer questions, earn points and help others
