My Sansa Clip (2GB) screen is not showing up (it is blank). When I connect it to Computer the screen shows up and I can able to charge it, I can copy songs and see songs only if I connect it to computer. If I remove it from Computer, I am not able to see the screen. Can anyone suggest what should I do ? I have formatted it, updated the firmware... Any suggestion is welcome...
If you mean that the songs don't show up on the computer screen, then you probably need to change the USB MODE setting on the Clip. To do this, disconnect the Clip from the computer, then scroll to SETTINGS. Select Settings, then scroll to USB Mode and select it.. (If your Clip is very old it might not have a USB Mode listed under SETTINGS. If this is the case you should update your Clip's Firmware from the sansa website). Older computers recognize the MSC Mode while newer ones should recognize either mode. (except XP Professional doesn't seem to recognize the MTP mode). Songs entered in one mode won't show up on the computer if you're in the other mode. If you mean that the songs aren't showing up on the Clip's own screen then this solution probably won't help. By the way, I've never had any luck with the "auto detect" mode.
The problem maybe the usb cord or it maybe the hardrive in the monitor hooked up to the network drive. If this doesent help i will try to help as much as possible.
just figured mine out. turn your clip off. put the slider in the hold or lock position. press and hold the center button on your clip. continue to hold while attaching the usb to your clip. keep holding the center button as clip powers up. after appox. 12-15 seconds, your computer should read the clip. i am running windows xp and this is the ONLY way my comp. will read the clip. but it works great!! good luck!
This model goes to "sleep" quickly by default - pressing any button will wake it up. The button that looks like a house (if the paint didn't get rubbed off already) allows you to go one level higher in the menu tree. Have fun with it.
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Hah, figured it out! Had to roll back my version of WMP, which can simply be done by (in XP) going to Start > Control Panel > Add Remove Programs, and then click on WMP11 in the program list. Click remove, and it will ask if you want to roll back to the previous version of Windows. Click yes, and it will roll it back to the previous version of WMP11. Now, assuming you have an active internet connection, after you restart your computer, it will ask if you want to update your WMP. Click yes, and it will re-install the version you started out with, replacing drivers, .dlls, and anything you were missing before hand. Long story short, the solution was patching the holes in the program. I can now plug my Sansa Clip 2GB into the USB port, and WMP will recognize it right away (I can almost hear a small voice from inside my computer saying "would you like tea with that, mr. guy?" hah). I also found out you can have more than one media player connected at the same time! How cool is that? Great if you're trying to set up multiple players with the same playlists (promotional type stuff, business type stuff, etc.).
Sandisk website will have it, and will have the vista compatible software:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
here is the link for the sansa updater.
Ok...here is something you might want to do....I know you already formatted your device a zillion times already but please do it one more time using the Format option under Settings menu in your device....then restart your computer....then plug in your computer again after restarting to see if it recognizes now.....if not...here is one thing you could do....go to this link
download the USBDeView software and see if the registry has the player in there....select it and delete it and then plug in your PC again to see if it will re-register the device and works...hope this will help.
