The workbowl, lid and disc on my Cuisinart Custom 11 food processor are jammed. I can't unlock the safety interlock or get the lid off. I unscrewed the 3 phillips screws on the bottom, but the top still doesn't separate. Suggestions?
Make sure the Pusher sleeve lock switch is unlocked, and then push the clip that says "Push here" inward and lift up. If this fails, send in to Cuisinart for repair (call first), or break the bowl, etc and re-order the parts (drastic and expensive, but effective).
-Tha Mp3 Doctor
Was this helpful?
Yes
No
Popular Solutions for Cuisinart DGB-300 Coffee Maker
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have...
(More)
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have follwed the steps in the manual. It doesn't make any noise as if attempting to grind. The grind processed is by-passed going straight into the brew mode. We used the non-grind for about 2 weeks. Thank you.
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go,...
(More)
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go, but now just beeps again. All parts are in place and water is in resevoir.
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of...
(More)
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of coffee - just started doing that. Unit was cleaned 3 months ago. Fred
cuissinart coffee maker part, model DGB-300; Need replacement of Reservoir cover...brown ...where...
(More)
cuissinart coffee maker part, model DGB-300; Need replacement of Reservoir cover...brown ...where can I purchase?
