I have no sound. when i press play on itunes, the play button will turn to the pause but the play bar does not move.
    Problem Solver:
  • 15 Answers
Try using the audio controls to make sure nothing is muted. go to your control panel and double click on "sounds and audio devices". make sure nothing is muted, and that your speakers are pluged into the green line-in jack
Posted on Mar 17, 2008
SOURCE:
Turn off demo mode
try pressing and holding the play/pause button on the remote. This should reset the unit and turn off demo mode.
Aug 24, 2015 | Samsung HW H550 Channel Wireless Soundbar
IPod classic stopped shuffling this weekend. I've had it for several months and it's worked just fine, but all of the sudden it stopped shuffling songs within playlists that were set to shuffle. ...
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
Jul 20, 2011 | Apple iPod touch
You tube videos start and stop
The videos need some time to buffer/load.
This is indicated by the pale red line that is usually in front of the play bar which is the darker red bar.
Pause the video for around a minute for the video to buffer.
Then push play button.
You may need to set the detail down to 240p to increase the speed at which it loads.
damnor01
Apr 11, 2011 | HP TouchSmart IQ770 PC Desktop
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
Frozen
press the MIDDLE BUTTON and MENU button at the same time
or
press PLAY and the MIDDLE BUTTON at the same time till you ipod resets
Jul 02, 2009 | Apple iPod mini 2nd generation MP3 Player
120GB classic ipod is corrupt
You will want to attempt to force the iPod into disc mode then restore using iTunes. With the iPod in disc mode, iTunes should show the iPod. You will have to restore the iPod to resolve the issue of corruption though. Please let me know if this does not resolve your issue. :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 17, 2009 | Apple iPod classic MP3 Player
My ipod says restore but when i try to restore it nothing happens
Then try this:
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Jan 25, 2009 | Apple iPod MA446LL/A MP3 Player
When connected to PC says there's no drivers and won't charge
Try this....... Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
If this does not resolve your issue you may want to go to www.fixyouripod.weebly.com
Jan 17, 2009 | Apple iPod nano
Audiobook download
Playing Songs, Audiobooks, and Podcasts on iPod shuffle iPod shuffle allows you to play your audio files in a couple different ways—you can play songs, audiobooks, and podcasts in the order in which they appear on your player, or let iPod shuffle work its namesake magic for you (that is, shuffle the files by playing them randomly).
Show Me How
If you want iPod shuffle to play audio files in the order in which they appear on the player, move the switch on the top of the iPod shuffle to the play in order (circular arrows) position. If you want iPod shuffle to play songs in random order, move the switch to the shuffle (crossed arrows) position.
ip02_playfnky_04_shuflebutton.gif This iPod Shuffle is set to shuffle.
To play music, an audiobook, or podcast, just press the Play/Pause button. To skip to the next song (or a different song if you're in shuffle mode, or a different chapter if you're listening to an audiobook or podcast), press the Next/Fast-forward button. To fast-forward through the audio, hold down the Next/Fast-forward button. To go back to the beginning of a song (or the previous chapter), press the Previous/Rewind button; press this button twice to go to the previous song or hold it down to rewind through the file.
To stop play, press the Play/Pause button during play. To turn off iPod shuffle, move the switch to the Off position (you shouldn't see green beneath the switch).
Jan 24, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Open Questions:
TOSHIBA customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This TOSHIBA USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 TOSHIBA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the TOSHIBA USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, TOSHIBA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA USA Calling TOSHIBA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA USA's phone numbers against each other. Contacting TOSHIBA USA in General While I8OO8O31O69 is TOSHIBA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA USA.
Oct 18, 2019 | Toshiba Computers & Internet
\Q;- PANASONIC customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This PANASONIC USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 PANASONIC USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the PANASONIC USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, PANASONIC USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PANASONIC USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PANASONIC USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PANASONIC USA Calling PANASONIC USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PANASONIC USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PANASONIC USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PANASONIC USA's phone numbers against each other. Contacting PANASONIC USA in General While [+I8OO-8O3-1O69] is PANASONIC USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PANASONIC USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PANASONIC USA.
Oct 18, 2019 | Panasonic Computers & Internet
KODAK customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This KODAK USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 KODAK USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KODAK USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, KODAK USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK USA Calling KODAK USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK USA's phone numbers against each other. Contacting KODAK USA in General While I8OO8O31O69 is KODAK USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK USA.
Oct 18, 2019 | Kodak Computers & Internet
\Q;- HP customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This HP USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 HP USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the HP USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, HP USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact HP USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP USA Calling HP USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP USA's phone numbers against each other. Contacting HP USA in General While [+I8OO-8O3-1O69] is HP USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach HP USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP USA.
Oct 18, 2019 | HP Computers & Internet
Computers & Internet Logo
50 people viewed this question
Ekse
Alun Cox
