Question about Dell E193FP 19" Flat Panel LCD Monitor
Vista video driver needed for Dell E193FP
I am using this Dell E193FP monitor with my vista machine and keep getting error, " Cannot display this video mode" when using the intel video driver.
Is there a third party video driver avaialble for this monitor to work w/ the vista OS?
  • 2 more comments
  • cjspurrier Mar 11, 2008
    Dell Desktop Vostro 200 mini tower
    OS: Vista Business SP1
    Trying any video mode:
    I have downloaded and installed
    onboard graphics: G31/G33/Q33/Q35 Graphics Controller
    Driver: R180002.Exe
    I have downloaded and installed latest drivers form dell and intel and after installing reboot and and logging in, I receive black screen with "Cannot display this video mode"
    1024 x768 at 60hz
  • cjspurrier Mar 12, 2008
    Yes I am sure the onboard video adapter is Intel G31/G33/Q33/Q35 Graphics Controller
    Here is the testing I have done thus far:
    1. uninstall & delete video driver
    2. download updated driver from Dell support page
    3. Adjust video display properties to 1024x768 32 bit
    3. Reboot machine in safe mode
    4. Install driver
    5. reboot and receive error, can not display this video mode
    6 reboot in safe mode
    7. uninstall driver
    8 reboot, machine is now using default vga driver and works fine
    However visita goes out and looks for an updated driver and installs the intel driver, when the machine is rebooted, because shut down at the end of the day, machine comes back with "can not display this video mode"
    I have been told by Dell tech support that there is not a vista driver avaialble for this monitor and that they would have to serach for 3rd party driver.
  • metall god Feb 06, 2009
    degfwdagsdfg
  • Dell Master
  • 13,433 Answers
There are no drivers for difrent monitors.
But if you provide your pcs brand, name, model.
I might be able to find a videocard driver witch might fix your problem.
Oh and what videomode are you trying to use?
Posted on Mar 11, 2008
  • 1 more comment
  • Ekse Mar 11, 2008
    What videomode are you trying to display?
  • Ekse Mar 12, 2008
    your monitor supports most of the resolutions from 640x480 up to 1280x1024.
    The problem isnt in your monitor, it has be in your pc.
    1. Might be bad drivers
    2. Virus
    What displaymode does your pc use since 1024x768 doesnt work?
  • Ekse Mar 12, 2008
    are you sure your Video adapter is
    Intel G31/G33/Q33/Q35 Graphics Controller?
I downloaded drivers for dell E193FPp monitor. the only files in the download are 2 text docs, a setupinformation, ICC profile, and security catalog files. no .exe file. how do i install driver?
in most cases you will not need to install drivers for you monitor. These drivers are for windows XP and 2000 - so if you have a later version you should not need them.
For windows XP or 2000 you should have a readme file... if not then download the Dell drivers from
http://www.dell.com/support/drivers/us/en/19/driverdetails?driverid=r83276
Run the program and it should extract to a place on your hard drive, and once complete it should open the location with the following files
e193fp.cat, E193FP.ICM, E193FP.inf, Readme.txt and Version.txt
The Readme file gives you instructions on how to install for XP and 2000
Jan 08, 2014 | Computers & Internet
My Dell Inspiron notebook keep turning display off and then go to sleep later.
Go into the Windows Control panel, then to power settings. There you can adjust the settings for the monitor sleep behavior, as well as computer sleep and hibernation.
There are seperate settings for while plugged into power and while on battery.
If you have trouble, just let me know which operating system (XP, Vista, Win7, etc) you are running and I will give you step by step instructions.
Hope this helps you,
-Ben
Sep 20, 2011 | Dell E193FP 19" LCD Monitor
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Need windows 7 drivers for Dell E193FP monitor, pls help
Look for Graphics drivers for your particular computer. Vista drivers should work fine.
Mar 09, 2010 | Dell E193FP 19" Flat Panel LCD Monitor
Dell E193FP 19" LCD Monitor to work with vista
Go to Start, Control Panel, Personalize, Display Settings, Adapter, List All Modes, then select the mode you want.
Good luck
Feb 15, 2010 | Dell E193FP 19" LCD Monitor
The monitor keeps going to 640 by 480 resolution. What should it be set to?
The resolution is set from the computer. Monitors will have a max resolution, but you will set it up from the display settings.
Most likely your video card or video driver is having the problem. Windows XP: Right click "My Computer" then click "properties" Click Hardware tab then "Device Manager" If you see a yellow or red mark over the video then you need to download the video driver uninstall the old one and reinstall the new one. You can the driver from the manufacturer website of your computer brand
Windows Vista: Almost the same steps Right click "Computer" then properties Click on "Device Manager"
If there are no yellow or red marks on the video device
I would recommend following the dell troubleshooting guide for your monitor http://support.dell.com/support/edocs/monitors/E193FP/En/trouble.htm
Nov 05, 2009 | Dell E193FP 19" LCD Monitor
Just plugged a Dell E193FP monitor into my emcahine - running XP - turned it on and video display said ''cannot display this video type''
The computer is not able to communicate with the hardware properly. It can be solved installing the Video drivers (The video card drivers AND the display drivers).
Check for updates with the manufacturer of the video driver.
To determine what Video card your computer has, just right click in MY PC - MANAGE - DEVICE MANAGER and click Video, check properties.
Good luck.
Mar 27, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Will the E193FP work with my computer?
I would suggest , check the monitor connections again. Dell flat panels are plug and play and donnot require additional drivers.
Make sure , you have not connected , both the analog (vga cable with a blue connector) and the digital (dvi cable with a white connector) to the back of your computer.
Refer to the the link below , to troubleshoot the monitor
Thanks
Proton
Nov 10, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
No video on monitor
Go to Start->Control Panel -> Display, Settings Tab, and turn down the resolution of your computer.
Mar 03, 2008 | Dell E193FP 19" LCD Monitor
Dell e193fp
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Dec 19, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Dell E193FP 19" Flat Panel LCD Monitor Logo
911 people viewed this question
Alun Cox
