Question about Dryers
Whirlpool washer how do i know when i put the tub back in place is there a piece on the bottem of the machine cabinet that could have gotten lose
    Problem Solver:
  • 6 Answers
About the only thing that may have come loose in the bottom of the machine is the block as I stated earlier. Since you stated that it spins I imagine the belts are all on. There could also be some springs holding the mount for the block that may be loose. You can clip them back on their mounts before you reinstall the block. You should be able to tell when you have the tub centered by looking in the top and see the sides of the tub are evenly spaced around the opening, and the agitator is in the middle of the opening.
Posted on Mar 11, 2008
Tub is off balance found a small spring broke, but do not know where to replace it. and some pins came off the bottom of a plate with some plastic covers around it.
The pins with plastic over the are no concern at all they were used for shipping when the machine was delivered it had a yellow strap under the lid that had to be pulled to release the tub and free it up so itdidnt bounce around and break something during shipment while being bounced around in the back of the semi truck that delivered it .
Now about the small spring that was found on the left side of the frame to the tub plate, to replace it the cabinet must be removed, to remove the cabinet remove the phillips screws from the back of the control panel(where the timer,water level switch ect are) pivot the contol panel up and to the rear and look and find (2) brass colored clips the roughly look ess(s) shaped one will on either side of the cabinet and attach to the rear plate,place a flatblade into the front portion of where those clips fit into the cabinet and pry them up and out,then disconnect the plug to the lid switch(it will be near the right side clip),open the lid place your hand in the front of cabinet under the lid and pull the cabinet off(whilei didnt search for it look on youtube for a video of how to remove the cabinet from whirlpool DIRECT DRIVE WASHER
Jul 18, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jul 02, 2010 | Kenmore 25862 Top Load Washer
Won't agitate,or spin!!!!!!
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
spinning.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
May 27, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer stopped working how do i know its the coupler.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
spinning.
Before pulling the cabinet however, I'd test the Lid Switch.
Apr 09, 2010 | Kenmore 23822 Top Load Washer
My Kenmore 90 series washer motor runs but the tub does not move
Mar 26, 2010 | Kenmore Washing Machines
Will not agitate or spin
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission as a fail safe device.
If the coupler (a three piece part) is broken or worn, the motor cannot transmit power to the transmission for either agitating or spinning.
Following is a Whirlpool PDF describing the operation and maintenance of top load, direct drive washers.
This is an ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Follow the directions to remove the cabinet, pump, motor and motor mounting plate. You'll see the coupler as a three piece unit.
The two plastic pieces with three prongs each fit on drive shafts on the motor and transmission and the rubber piece with six holes fits between them.
If the coupler is worn or damaged.
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
Oct 08, 2009 | Kenmore Washing Machines
The top load, direct drive, neutral drain Whirlpool / Kenmore washers use a "Motor Coupler" between the transmission and motor.
When the motor goes into drain / spin mode, it reverses and drives the pump to drain the washer.
If the motor coupler is damaged / broken, the motor cannot get power to the transmission to agitate or spin.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes.
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
Tub is very loose/wobbles during spin
could be the balancing spring. but if you do not know where it is hooked, then that would be a problem.
investigate and look for holes where it would be fitted to hook a spring. if there are three of them , follow the other two which are still hooked correctly.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Remove top from Kenmore 101.24722300 washer
rberliner The complete instructions you can find here: http://www.askgene.com/2007/01/26/whirlpool-kenmore-washer-direct-drive/how-to-remove-the-cabinet-on-whirlpool-direct-drive-washer-2/ Gendos...post back
Feb 20, 2007 | Kenmore 24722 Top Load Washer
Dryers Logo
Top Dryers Experts
