Question about Phonic MAX 2500 Amplifier
Phonic Max 2500 blocked/protected
My amp phonic max 2500 doesn´t work. It have a system of some sort that blocks the sistem. Does exist any way to unblock the amp?
The inside lights turns on about 2 seconds and then shuts off. With the speakers connected and disconnected.
Help me.
Paulo Ricardo
Portugal
The problem of shuting down of amp. is some of output driver are shorted or open check the output driver and predriver
Posted on Mar 13, 2008
SOURCE:
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
Feb 20, 2013 | Numark M6usb M6 Usb Four Channel Table Top...
I have two phonic 2500 amp, whats the correct way to hook up the crossover
first is how u want to run everything and a bit more about wat u have to go with the rest of the gear would help us answer u better
Dec 06, 2011 | Phonic MAX 2500 Amplifier
How to hook up the crossover to this amp
depends on how u want to use the setup ........ any more info on wat u have etc can help with telling u how to set up the stuff properly
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
Hello, i need phonic max 2500 plus diagram
  • 860/1500/2500 MAX 860/1500/2500
    archive.espec.ws/.../PHONIC%20MAX-%20860%201...
    Traduire cette page Phonic reserves the right to improve or alter any information supplied within ... MAX860/1500/2500 SERVICE MANUAL ..... HEAT SINK MAX SERIES PHONIC.
  • PHONIC max 2500 - Service Manual free download ...
    www.eserviceinfo.com/index.php?...PHONIC+max+2...
    Traduire cette page 15 janv. 2009 - Search results for: PHONIC max 2500 (found: 50 regularSearch) ... Audio, 2891 kB, 2178, Service Manual, PHONIC max 2500, VASILICH500.
  • Amplifiers :: Analog :: MAX 2500 Plus - Phonic ...
    www.phonic.com > Home > Amplifiers > Analog
    Traduire cette page Phonic's MAX 2500 Plus Power Amplifier provides 1500 Watts of power at 8 ohms (bridge mono) or 750 ... MAX 2500 Plus Simplified Chinese User's Manual.
  • PHONIC MAX 860 1500 2500 Service Manual free ...
    elektrotanya.com/phonic_max...2500.../download.ht...
    Traduire cette page PHONIC MAX 860 1500 2500. Sponsored link. Type: (PDF), Size 2.9 MB, Page 27, Category: AUDIO - SERVICE MANUAL. Warning! If you are not fa
  • Nov 19, 2010 | Phonic MAX 2500 Amplifier
    Auodio clipping
    Too high volume, too small impedance?
    Feb 25, 2010 | Phonic MAX 2500 Amplifier
    Phonic Max2500
    you have real problem in safety contol circuit which shut down the unit to protect the amplifier from damage
    Mar 06, 2008 | Phonic MAX 2500 Amplifier
    Phonic MAX 2500 Amplifier Logo
    494 people viewed this question
    Top Phonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Gil Shultz
    ray gallant
    ray gallant
    Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
