Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Ge dishwater problem
Won't fill with water
Glasses have a film that wont wash or rub off
Posted on Dec 13, 2008
Reset dishwater
No fill..no water..
Check the problem on the filling section...
The machine should fill first of all and after this to run in any of the cycles.
Can be..solenoid for fill.
the water line is close :)
the drain solenoid is broken and all the water is draining
Good luck
Jun 30, 2013 | Bosch Dishwashers
Water won't come into dishwater
Make sure your brass line or braided line is hooked up with no kinks or pinches, Then make sure water to valve is turned on.
Sep 05, 2012 | Whirlpool 24 in. DU920PW Built-In...
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Dishwasher did not drain out all of the water
run it again on the hot cycle...if that doesn't work...you have a clogged drain hose or a defective pump.
Apr 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwater not filling with water when switched on.
Hi nitwit2,
I'm Harvey the Master Plumber.
Your problem is: Dishwater not filling with water when switched on.
Electric on? Good. 9 times out of 10 it's a bad solenoid valve. It's under the d/w behind the kickplate on the left. I don't recomend this repair for the average homeowner. You might look in the Repair Directory for a repairman. If you're up to it, I find removing the d/w from the cabinet facilitates installation.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Bosch Dishwashers
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I was trying to find a simple solution so I wouldn't have to wait all day for the GE repair man. The dishwasher was still under warranty, I called GE and the repairman was to arrive between 1 and 5pm today, He arrived at 4pm and determined the valve was bad, he replaced it and it works fine. I did basicily waist my day waiting for the repairman, I'm glad it's now working. Woody.
Mar 11, 2008 | GE 24 in. GSD4060JSS Built-in Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
71 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
