Freecom 250 Gb Hard Drive
I attempted to upgrade my pc from Windows XP to Vista. I had to abort the process as my pc did not have the correct configuration. I have reloaded XP but now find that although my computer recognise my Freecom device it does not show up as a device on My Computer; equually attemting to make a new backup creates the message in Freecom Backup 'No support device detected'. My backups for both devices and photosare all on my hard drive so I would like to retrieve them please.
Can you tell me how to fix this problem please.
I look forward to hearing from you.
Des V
    Genius:
  • 1,019 Answers
Hi des,
you need to install windows XP, on a different hard-drive.
even if it,s only 10 gig plus.
You can then access the drive.
Your problem is here, is that you,ve upgraded from XP to Vista, theres a possibility, that you may have lost or even formatted your freecom hard-drive.
No-Support-Device detected, is saying that your USB devices are not functioning correctly.
Check in the bios that the USB devices are enabled, to operate your hard-drive. ( this is assuming it,s a USB drive )
Hope this helps you out.
Mike @ compurepair.
Posted on Mar 11, 2008
I need to intall a freecom usb external hard disk to an old computer uses windows 98 an i havent a drive Any help please? How can download s driver for this disk?
Unfortunately, the company only supported: OS: Windows 2000 / XP / Vista / Mac OS X v10.3 or higher and Time Machine (OS X v 10.5 Leopard) compatible, for their USB hard drives.
You would need someone to write a driver for you or to connect to a computer with a supported OS.
I wish that I could be of more help.
Nov 13, 2010 | Freecom 80 GB USB 2.0 Hard Drive
Hi I purchase an Iomega External Hard Drive 500 gb and I am using it in PC format however, when I connect the hard drive it gives me an error when I try to format it. I tried Windows vista home Basic,...
ur harddrive couldnot be formatted probably due to the infection of virus.
try this use window xp and connect ur hard drive open task manager by Pressing CTRL + ALT + DELETE
click on the process tab a list of all the processes going on will come,there u will find a process named explorer.exe
right click on it and select end process tree click yes
after that click on applications tab and click new task
enter explorer.exe on textbox and click ok.
now dont open ur external hardrive ,open mycomputer then quickly format ur hard drive.
Mar 31, 2010 | Iomega 33089 250 GB Hard Drive
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
Home Premium / Business / Ultimate
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
Source: http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Jul 11, 2009 | Microsoft Windows XP Professional
Freecom 400gb not being detected
you may need to format it via Computer Management->Disk Management if there is nothing in it.
Apr 17, 2009 | Freecom (24358) 160 GB Network Hard Drive
Coppying speed is slow
in vista you need to change the remote differential compression.  Can be found in control panel?programs?windows settings I believe.  Turn it off.  As far as XP, sounds like a problem with the hard drive or memory.  I know of this issue in vista, but never ran into it with XP.
Mar 06, 2009 | Computers & Internet
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
Formating hard disk
IF the old PC motherboard will recognize the drive while booting up, Windows 98 will also see the drive after boot-up. You may have to reformat the drive into smaller partitions.
All you have to do is physically install the drive in your old computer and attempt to boot. After the computer boots up, if the drive does not show up shut down and put the drive back in your old computer. Use the manufacturer's partitioning software available on their website to change the drive from one 250 Gb partitions to five 50 Gb partitions.
Feb 15, 2009 | LaCie (300728U) 250 GB Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
I have a SimpleTech 250 GB external hard drive and would like to transfer the data from the hard drive onto my new HP laptop which is running on Windows Vista. However, when I try to sync, the name of my...
U can remove the drive from the external unit and hook it up to your vista computer as a secondary drive. Boot up the vista, use windows explorer, and transfer the data from the secondary drive to either your primary or a usb stick.
Jun 25, 2017 | SimpleTech (sti-u2f36/250) 250 GB Hard...
WANT BOOTING OPTION WITH VISTA OR XP
you have not installed both windows correctly, you may need to install both windows again and select multiboot option.
Oct 17, 2008 | Computers & Internet
Computers & Internet Logo
179 people viewed this question
Alun Cox
David Payne
David Payne
