Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
Use the Windows XP startup disks or the Windows XP CD to restart your computer.
When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
Type the administrator password when you are prompted, and then press
ENTER. If no administrator password exists, just press ENTER.
At the command prompt, type the following commands (press ENTER after each command):
cd \windows\system32\drivers
ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
At the command prompt, type the following command, and then press ENTER:
copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
Yes, it should run WinXP. The minimum system requirements to run both Windows XP Home and Professional are 233Mhz, 64Mb RAM and 1.5GB hard drive space. I have a Toshiba Tecra 8000 that still runs XP, a little slow, but has run smoothly for 5 years.
The setupdd.sys error is most likely a due to a defective hardware like RAM. Try installing only one ram if you have two to see if either one is defective; it should work for most users.
