Question about Epson Stylus Photo R260 InkJet Printer
Epson R-260 Printer
Both the red and green light on the top stays on. No matter what I do, I am unable to get the red light to turn off. Any suggestions?
bjc2404@yahoo.com Thanks
  • Anonymous Apr 10, 2008
    All inks are showing as being out of ink. However all inks were taken out and put in an identical printer and they showed all at least 3/4 full. Help!!!
  • EpsonUser Apr 10, 2008
    Yes, we have the same problem with the Epson R260. All the inks have been replaced and the red ink-light stays on. We have turned the machiine off and restarted it without any difference.
    This is really strange and too bad because it is we have been using other Epson machines over the years with very few problems.
    Genius:
  • 1,447 Answers
Which Led light is Red ? Ink Button? Open the printer cover then press and release the ink button, printhead will move to the center in which there is an ink out indicator pointing to one of the ink, press and release the ink button several time to determine what other ink/color are out. replace inks and try printing after getting a solid green light on power button...
Posted on Mar 12, 2008
My Epson C48 printer has stopped working
http://files.support.epson.com/pdf/cx48__/cx48__qr.pdf
There is a whole section devoted to troubleshooting the different lights, and if they flash or not. Without more of a description from you I was unable to discover right away which error it was, but you should be able to find out no problem with this manual.
Apr 08, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
MY EPSON STYLUS C46 WONT ACCEPT THE BLACK INK WHICH IS NEW THIS IS THE SECOND ONE. THE RED LIGHT FLASHES AND THE GREEN LIGHT STAYS ON
Check status monitor? Black ink not recognized or what? If not recognized, red light just on. But flashes? It's may ink nearly out (low level ink) or printer need service. Check it. using SSC utilty to resolve. Reset protection counter and clear counter overflow.
Jun 27, 2009 | Epson Stylus C46 InkJet Printer
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
Epson 2400 problem
Maybe your epson printer has reach the printing warranty.. try to reset your printer by using SSC epson printer resetter.. ^^ cheer..
Mar 13, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
242 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
