Back to:
Tags:
Brother EM-530 Typewriter
HELP PLEASE!!!! (by 2 users)
posted by PollyAnn on Mar 11, 2008
The typewriter is a Brother EM-530 and the ? / : ; key doesn't work the way I would like for it to. Example :::: blank p:f blank
it should be ::::: blank p/f blank
How do I fix this??
also it is with some other keys:::
1/4 " 1/2 ' doesn't work as in nothing prints when you press the button.
[ ] | when that button is pressed with the shift key , it prints out an <................. when that key is pressed alone, nothing prints.
: ; N with the ~ over it when that button is pressed, it makes a @
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 20, 2008
I have the same problem. I was told that I should install a new Cassette Daisy Wheel (English Prestige 1012) and I did, but I continue to have the same problem. I press the period and coma keys and the close symbol ) prints. I press the "F" key and nothing prints, but when I press the "G" key it prints the @ symbol over the letter "G".
How do you reset the typewriter back to the original factory settings so I can regain the use of the keys for which they were intended?
Best Solution
posted on Apr 24, 2008
FixYa! (100)
EM-530
Rank:Apprentice Apprentice
Rating: 100%, 6 votes
I just talked to A Brother Customer Service Agent, I have a EM-530, and was having the same problem with my keys and symbols. Turn off your typewriter, hold down your Code, Shift and Tab key at the same time. Keep holding them down while you turn your machine back on. This will restore your factory settings competely. You will have to change your margins and tabs to where you like them again. If it continues to not type the write symbols, push code and the letter "K" and watch the upper left lights with roman numerals I II & III (KB is under the numerals), when the light is just on roman number I, let up the code key, turn off for ten seconds and then turn it back on. The keyboard has now reset and all should be well.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HELP PLEASE!!!!:
I don't want to Accept this solution
Solution #2
posted on Mar 15, 2008
Not Rated (0)
RadarRon
Rank:Guru Guru
Rating: 87%, 61 votes
I suspect one of two things
1) the daisy wheel (print wheel) you are using is not for a brother typewriter.
2) the daisy wheel is not English from what you describe sounds like a Spanish print wheel
Thank You!
Can you Help with these Typewriters problems?
Typewriters
Hi thereI use the dymo labelmanager 300. It was working...
I have 2 lines of information that need to be typed on 13...
When typewriter turned on, pitch beeping noise will not...
I cannot get my to stop tabbing to the end of the page...
Typewriters
I am Diploma holder in L.E.E. and Ex-Servicemam...
Loading problems.
Repair Service
Find Typewriter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
