Question about Konica Minolta Di1610 Copier
Printing problems We have a Di1610, and about 3 months ago, it started printing lines on the papers. It's not just smudges - it looks like it's almost reprinting the information. It does not seem to make the lines when we print something like a scanned document, but when we print from excel or word, it does this. On a word document we printed yesterday, there was the mark right in the middle of the page. I replaced the toner, shook the toner, and cleaned the drum. It is possible that I need a new drum? Can I still get a new drum for this machine?
  • JMRF12581 Mar 12, 2008
    Not to sound like a complete moron, but what's a fuser?
    The total count is 20538.
  • JMRF12581 Mar 14, 2008
    That was my thought, too - I just wasnt sure of the techincal terms. We have the part ordered, so hopefully it works! Thanks!
    Problem Solver:
  • 4 Answers
What's the machine counter? Try to clean the fuser.
Posted on Mar 11, 2008
  • Anonymous Mar 13, 2008
    If you use a compatible toner you have to clean the fuser ( heat ) unit and replace the drum.
    Sorry for my english i'm not to good at it.
    If the image is repeating on the copy/print is because of the fuser
    If there are lines on the copy/print you need a new drum
    ( drum life 16000 )
SOURCE:
The print comes out with black printing black and red stripes.
I ran a full clean and maintenance on mine and it worked fine for another month but then it started smudging and putting lines over he paper again. I ended up throwing it and buying a new printer as the Guy at the shop said its worn out. After 4 years of heavy duty printing, it wasnt a bad run.
Sep 16, 2015 | Canon Pixma MP450 All-In-One InkJet...
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
I have an HP3500 which I've had from new since 2004. On the whole it's been remarkably reliable but recently I have problems with a multicoloured stripe which appears down the lefthand side. It...
Hi Richard,
Dots, Lines and smudges on the printouts are usually due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and inspect them. You may observe the lines on the green drum. Gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Observing the PCR with the help of a sharp torch light would let you assess the condition of the PCRs at the corresponding location where lines are appearing. Replace the Cartridges one by one and inspect the prints for the changes. I think you would be able to identify the faulty cartridge/ rollers. Also, if the waste toner area is filled and/or the plastic wiper/ cleaning blade removes the leftover toner/ waste from the drum and holds the waste is worn out, it results in spilled toner usually at edges and at early stages lines only.
Moreover, the function of the fuser is to fuse the toner onto the paper and it is usually done at the end of the printing process just before the paper is ejected (and the image/ toner on the paper is just fused - not changed). The fault at the fuser area usually results in smudges, ghosted image or unbind toner (which easily gets erased when touched). The time during the printing cycle when the toner is spread on the paper, additional toner (resulting in lines) is shifted to the paper due to cartridge related issues, which results in lines. Note that after cleaning the rollers, the print quality improves and the lines disappear or lighten. Try and check if the above suggestions work.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Office Equipment & Supplies
Use a hp deskjet 35200(3500). when unit is printing all lines are blurd and paper gets black streaks all over. The printing is unreadable and smudged.Is there a manner to clean this up?
Streaks:Cleaning interior
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 06, 2011 | HP Office Equipment & Supplies
After numerous cleaning cycles the nozzles on my Pixma MP970 still show streaked patterns when printing the nozzle check. This printer has always has had poor print quality mainly black text. We got it as...
It will need a new printhead, QY6-0062-000, around $80.00. Leaving it sit and not printing just makes the problem worse, as more nozzles on the printhead get plugged. You get 90 day warranty with refurbished units and if it started out crappy you should have had a shop look at it, that model can print super photos! A new printhead will bring it back to life.
Dec 24, 2009 | Canon PIXMA MP970 InkJet Printer
Changed cartrige, now have smudge lines on paper
please check the cartridge and see if it is the recommended one the printer..
if it is .... remove it ,clean the print mouth, re fix it and try printing...
sometimes refilled cartridges also give the same problem. please check that too.
May 26, 2009 | HP LaserJet 1020 Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Konica Minolta Di1610 Copier Logo
111 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
