Question about Mintek DTV-263 26 in. LCD Television
Mintek Fix Ryan, Why can't I accomplish this by just plugging in the two audio wires from the RCA composite cable into the jacks on the set? What is different about soldering in the connections as you described as opposed to just plugging in the red & white audio jacks? What can I use as an inexpensive amplifier or receiver to power the speakers. I don't want to spend a lot of money for this purpose? I know you suggested the Onkyo but that is a couple hundred $$. Can you suggest some other cheaper source to power the speakers. Also how do I turn on the TV itself after I make the cable connection to my HD cable box? Will it come on as soon as I plug it in or will I have to use the on/off switch on the side of the unit. I don't have a remote for the TV. Can I plug the set into the rear of my cable box so that I can turn it or with the cable box's remote which is how I have it setup with my other TV. In either case will I have to reconnect the plastic interconnect and spade ground that comes from the on/off and other control buttons on the side of the unit? Mike
    Problem Solver:
  • 11 Answers
Mike
The biggest reason is the input on your TV will be stuck in DVD mode. Therefore the set expects any audio to becoming from the DVD player and not inputs on the back of the set. So every input on the back of the TV except for the component input is non functioning. Another reason is that you have no way to control the volume of the TV since there are no functioning buttons save the power button.
If you cut the speaker wire in the TV and solder to the respective RCA connections on the back or side of the TV you can treat the speakers passively, meaning there must be some sort of amplifier to power them. You could also just splice some wire to the cut speaker wire to extend the speaker connection to an amplifier, but I'm not a fan of loose wires coming from the back of my TV.
Therefore, using this set up you would have your cable box attached to your TV and an amplifier of some sort, and the amplifier attached to the RCA connections you soldered for the speakers.
Here's an amplifier that would work for fifty bucks:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-958
To turn the TV on just make sure the power button is pressed (this will put the TV in standby) and then press any other button on the side of the TV: Source, volume, any of them will work.
In order for your cable box's remote to work it will need to be programmed for the TV. I have been unable to find the program codes for the TV, but I do know that Comcast's cable remote will work if you do the code search. You do need to reconnect all the grounds that you disconnected as well.
Let me know if you run into anything else
Ryan
Posted on Mar 11, 2008
Pyle troubleshooting
The projector has built in speakers.
Aug 06, 2014 | Pyle Home PRJHD66 1080i Front Projector
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
Need cords
It should have the following connections:
Analog audio out;
Optical digital audio out
Composite-video out
Headphone jack
If you want to conntect the player to a tv use a RCA cable and connect it to the input on the TV
Mar 08, 2011 | Mintek MDP-5860 Portable DVD Player
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
THERE ARE 3 WIRES YELLOW,WHITE, AND RED WHICH WIRE I CAN DO PROPER CONECTION for get DVD WHICH JUCKS I CAN PLUG?
OK, what you have is the Composite Video cable (Yellow RCA plug) and the Audio cable for Right (Red RCA plug)) and Left (White RCA plug) audio channels. You just have to look at the back of the DVD and locate the Composite VIDEO output jack and Audio output jacks, just match the colors. Sma thing on the TV, just look for either AV1 or 2 Composite Video input jack and audio input jacks.
Set the TV to select the video source you have the cable plugged into, and that is.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Nov 29, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Can i hook up cable to mintek player
the answer is yes. Check the sides of the player, you will see a yellow jack space, just like the earphone jack space which is green.
The yellow jack space is called "AV OUT" that where wire will be connected from the player to TV.
The wire you will be using is 3.5mm to RCA Video cord. There is 3.5mm to RCA Audio, so make sure you get 3.5mm to RCA Video cord.
I hope you understand my message.
Good luck.
Apr 16, 2010 | Mintek MDP-1030 Portable DVD Player
What kind of cable do we need to connect the video and audio output from a Mintek MDP-1030 DVD player to a TV with component and composite input?
IN MOST ELECTRONIC STORES I.E. RADIO SHACK. THEY SELL THE CABLES TO STEP UP FROM YOUR VIDEO JACK (WHICH I'M GUESSING LOOKS LIKE A HEADPHONE JACK) TO A YELLOW VIDEO CABLE. THEY ALSO SELL THEM FOR AUDIO AS WELL.
Feb 20, 2010 | Mintek MDP-1030 Portable DVD Player
Mintek Fix
Mike
No problem. What I was suggesting you could do with the speakers is to splice the positive (it should be red or white) speaker wire to the hot part another separate RCA (I used the side input) jack and the ground to the jack's ground sleeve (the outer part). So the process is similar to what you're already doing with the component RCAs and wires. Once this is done you can hook a receiver up to the built in speakers in the TV with no hassle. The speakers will not be powered, however, so you can't just hook the audio output from your cable box to the TV. All this process allows you to do is hook a powered amp or receiver to the speakers.
What I meant by saying to make sure there are no grounds was to double check and make sure each bit solder did not bridge over to another strand of metal or the metal chassis of the TV and cause a short or a ground.
Anything else, just let me know.
Ryan
Mar 11, 2008 | Mintek DTV-263 26 in. LCD Television
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
Mintek DTV-263 26 in. LCD Television Logo
163 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
