Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Tv problem green LED light continues flashing, will not go out even when I push the reset button. Mitsubishi WS-55613 will not turn on. Green light on front blinks continuously. I have pressed the system rest, but light will not stop blinking.
  • 796 Answers
Can you tell in what patter does the light blinks??
Posted on Mar 11, 2008
  • isaac johny
    isaac johny Mar 11, 2008
    replace the 4 1000mf 16v capacitors on the DM module. it is the board
    located in the metal case to the left hand side of the chassis( looking
    from back). VERY DELICATE BOARD BE VERY CAREFUL and make sure to check and the polarity of the caps once finished
SOURCE:
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
TV will not power on,reset light is blinking and continues after following reset instructings
Probably needs a DM board.This is avery common problem and the board may not be available anymore.Sometimes you can repair them by replacing bad capacitors on the DM board.
Nov 04, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Flashing green button, won't reset or turn on
You can get the complete service manual for your set at the following link and they will provide free support to help you do the repair and even send you the instructions with pictures on how to do the DM repair. Your set Is the V23 chassis mitsubishi and thats how you have to select the manual. V23. Heres the link they email the manual to you instantly.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Mitsubishi WS-55613 55" Rear Projection...
MITSUBISHI BLINKING GREEN LIGHT
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
Nov 15, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
214 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
