Question about Nokia N95 Cellular Phone
Nokia n95 just got nokia n95 today and worked ok for first few mins but now has appeared to have frozen, can't get menu screen up at all, in fact it keeps going into standby mode i think??? was setting theme on phone when this happened, any ideas how to rectify the problem as no matter which button or key i press nothing seems to happen thx
    President:
  • 1,017 Answers
You could try this, it worked on my N95. But not on my mates. So it's up to you, this will reset the phone, or not, but whichever way it won't damage it.
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Posted on Mar 11, 2008
Got n95 wet didn't drop it in water just in my pocket in heavy rain, it did work but stopped about 15 min later and now 24hrs later it turns on appears to have a backlight but blank screen what can i do?
Dear user,
Immediately put if off, remove the sim and battery, removable panels if any and keep it for drying preferably in an area with +35 C temperatures but not too hot also.
This should have been done when it got wet itself, but still try this out.
If it does not work fine after doing this then you need to send it for repairs.
May 03, 2011 | Nokia N95 Cellular Phone
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
Nov 24, 2009 | Nokia N95 Cellular Phone
Hi, I 've got a nokia N95 and the screen has gone blank - I've bought a new screen and tried fitting it but not sore if im doing the right thing. There does not appear to be a hinge to keep the ribbon for...
Hey there! I would go into detail but I think it would be better if you got a few pointers. try this link. ;) Hope it helps.
www.noeman.org/.../63803-how-dismantle-n95-8gb-pics-inside.html
Aug 26, 2009 | Nokia N95 Cellular Phone
No display, Phone boots without video and with limited functions
You can try a software update by downloading the Nokia Software Updater from the Nokia web site. Do this even if it is the same SW version.
*******MAKE SURE YOU BACK UP YOUR DATA 1ST ON PC SUITE*********
If this does'nt work then it is a mechanical problem. Will need to go into a service cnter to get repaired, Should be covered by the warranty, taking it back to the place of purchase
Feb 06, 2009 | Nokia N95 Cellular Phone
My nokia n95 turn to white screen.
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Jan 30, 2009 | Nokia N95 Cellular Phone
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
N95 UI Gone Crazy
dear,
most probably it happens with stuck button. may be the casing is not properly fixed with the phone. check it first. sometimes, it happens, that a button seems to be ok but physically it is stucked. if problem persists, then try with removing the memory card and do a master reset, if necessary
Jul 26, 2008 | Nokia N95 Cellular Phone
Nokia n95 home screen
I have tried to remove the vertical menu's while maintaining the horizontal shortcuts above, but it doesn't seem possible via the N95 menu. I'm sure there's a more extreme method, but that would be way too much of a pain....
Anyhow, if you would like to remove all of the shortcuts, here's the procedure (N95 non 8GB):
Settings -> General -> Personalisation -> Standby Mode -> Active Standby (OFF)
On my old N95, Settings are under "Tools" in the main menu, however, this may have changed on the newer versions. Although this may not strictly be the procedure for the 8GB version, hopefully it will help.
Cheers
Jul 21, 2008 | Nokia N95 Cellular Phone
Nokia n95
That circles mean the progarm is running. The n95 keeps apps running in the backroun. To see the apps running u can go in to the menu and look for the circle, or u can press and told the menu key this will give u a list of the apps. U can also exit the programs from this by hitting the clear key. If you press the end key or exit the progarm with out hitting the exit button then it will keep running.
Jun 15, 2008 | Nokia N95 Cellular Phone
Nokia n95
well it sounds like you have two major problems first you need to get the lcd change and the phone's need to have the firmware reflash........take the phone to a recognise mobile service center and have them replace it for you and fix the freezing issue.
Mar 11, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
95 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
