Question about Dell Dimension 2400 PC Desktop
Hello i think my hard drive is fell how can i fix the problem?
  • bezi Mar 12, 2008
    when i try to repair the pc the setup cannot detect my hard disc ?so what can i do ?
Thanks,i bought hard disk and i want to load it but i donn't know how i handle it.i mean the partition staff and so on
Posted on Mar 24, 2008
    President:
  • 2,351 Answers
What makes you think your hard drive has failed?
If you think your hard drive has failed you would get a message as your system started up. Something to the effect (can not find a bootable media type). If you have no display on your monitor but you see the lights on your PC lighting up & flashing. More likely you have a video issue. Pay close attention when you start your PC. Listen for a single beep as it starts up. Watch the green light on your monitor, see if it turn to the color amber.
Watch the front of you PC as well. Do you see any led's light up?
Posted on Mar 11, 2008
  • Mike Peluso
    Mike Peluso Mar 13, 2008
    You must enter your bios. If your hard drive in not listed in your bios than there are a couple things you need to check.
    1. make sure your data cable is connected correctly.
    2 make sure the power cable is connected correcty to the drive
    If your bios still does not see your hard drive & the drive is an IDE re-check the jumper settings are correct.
    3. Find the maker's name of the drive. Write down it's serial No#. Go to their web site & download their hard drive utility software. Read the instructions on how to creat a bootable floppy disk so you can test the drive. If any of the test fail & the drive is warranted. Have it replaced. Keep a recoard of the test results to give to the Mfg.
  • Mike Peluso
    Hi bezi,
    Chances are your hard drive has failed. Your Dell came with a 40GB ATA/100 hard drive. You can use a local store near you to buy a replacement or you can use an on-line store to replace your drive. If you are not that familiar with the interior of your computer I suggest you leave your current hard drive installed until you get a new hard drive.
    I'll list a link or two below where you can buy on-line a compatible new hard drive for your Dell.
    http://www.tigerdirect.com/applications/...=
    I choose Seagate because they carry a five year waranty. This site does not carry a smaller size other than the 80GB drive.
    http://www.zipzoomfly.com/jsp/ProductDet...
    This site shows the same drive & size for less.
    Once you replace your old drive, just put either your restore CD into your cdrom or your windows CD into the cdrom & install your XP Home edition that came with the Dell.
    If you have any more question or need help with anything just post back here & I'll help you out.
    Thanks for using FixYa.
    Have a good day!
SOURCE:
I have a Toshiba 55 flat screen TV, only a month old. The model number is 55L310U. The TV was knocked over. Everything is working properly except half the screen is black.
You'll need to replace the panel - else the cable has popped out.
I would recommend taking it into a store instead of attempting to fix it yourself
Apr 12, 2016 | Toshiba Computers & Internet
My notebook fell off table, did not break externaly but now fails to detect hard drive . what can i do to fix
Unfortunitly, you hard drive's needle may have been knocked out of wack and will not access the data anymore. 2 solutions here:
1. New hard drive and reinstall everything. (Easy)
2. Let a data recovery provider retrive the information from the damage disk and put it on a new one. (Expensive and time consuming.)
Good Luck
C2Solutions
Feb 15, 2011 | Computers & Internet
Hard drive fell can't read info
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 13, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
MY cOMPAQ pRESARIO CQ60 fell and cant complete boot
Most likely in this case, the damage is to the hard drive or its connection to the motherboard. The CQ series though has a three point screw attachment for the hard drive so Im more inclined to think that the shock of the landing has damaged the read/write head on the hard drive. If you happen to have another hard drive for a laptop, try installing a new drive and run the installation disc and see if it will complete and boot completely....if it will then the problem was the old drive.
May 23, 2010 | HP Compaq Presario CQ60-249US Notebook
My portable harddisk snt working anymore after it fell hard
Sounds like it's hooped. Only way to recover data is to try to take it to a data recovery lab.... which can be pricey.
Sep 26, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I have a LaCie 320GB hard drive that accidentally fell off my computer tower. The tower itself is on the floor, so it only fell about 20 inches at most, but when it fell, it was in the middle of...
The only thing I can think of to try is to actually remove the drive from the enclosure and connect to the computer internally. Of course that will void the warranty, but if you are technical enough to do that, it may work inside the computer.
In other words, the problem may not be with the drive, but instead with the enclosure.
Although I would guess the drive is shot, as it was writing to the disk when it was dropped.
Sorry for the bad news...
Jul 15, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Files won't open on external hard drive after it fell 18 inches
ooo I have the same prob but mine.. the computer just doesnt recognise the external drive at all well if u find the solution plzz helpp...thnxx i hav evrythin on itt nd i need themm...
Jan 02, 2009 | Western Digital 500GB My Book World...
Harddrive fell on floor power is on wont work
HEllo your hard drive is spoilt. you cant do anything about it.
thanks
Dec 20, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
83 people viewed this question
Ekse
Clive
Clive
Alun Cox
