Question about Apple iPhone Smartphone
Keypad problem After I dial the number and hit 'call' I get another screen where the keypad icon is greyed out. Mute , speaker and contacts work; but keypad, hold, and add call are greyed out and can't be used. Any suggestions? When I try to dial the numbers on the keypad they won't stay on the screen. I have to save a number in my contacts before I can dial it. This did not happen initially, but now I can't use the phone like a regular phone, and it's very annoying.
    Problem Solver:
  • 10 Answers
Try restoring or reset settings
Posted on Mar 11, 2008
SOURCE:
Fluke Networks 42801009 Ts42dlx keypad and loudspeaker suddenly stopped working
some meters use a spring that makes contact between the two halves of the case, and often it is used as a ground for speaker & keys.
Oct 11, 2012 | Fluke Networks 42801009 Ts42dlx Set W/abn
I installed acier theme in my iphone 4.and now the dial pad does not respond to any other numbers except *,0,1 and 2..please help.
I have the same problem but i got it fixed.
Just follow these steps,
1. Borrow another mobile phone from anyone close to you and have a miss call on your iphone.
2. Obviously, you will see a missed call on your iphone. Slide the notification to call back.
3. Once you see the call back signs (mute, keypad, speaker, add call, facetime, contacts) quickly press the home button.
4. If you successfully get into home screen, go to settings menu and turn off your screen lock (SETTINGS>GENERAL>PASSCODE LOCK)
5. And lastly, uninstall that theme and never use it again!
HOPE THIS HELPED YOU! (^^,)
Apr 17, 2012 | Apple Iphone 4 - 16gb - White gevey...
How to save numbers on mororolla razor phone to sim my screen is smashed so can't see what I'm doing.
  • Create a new contact in your phone by selecting one of two options. First, enter a telephone number as if you were about to dial it. When you do, you will see the option to "store" it, this button is located at the bottom left side of the screen. Just hit the button and it will take you to a screen titled "Save." Select "Create new." Choose the category you want the number to be stored as. Alternatively, add the number as a contact
    Select the "Contacts" button at the bottom right hand of the screen. This will then retrieve your full contact list. Once you are there, select the "Options" button at the bottom right side of the screen. Once you do this you will be taken to another screen titled "Options." You can either press the number "1" to select the "New contact" option or press the "Ok" button by pushing the center button on the directional pad above the number keypad. You can now add all of the information that you want.
    Enter the name of the contact. This field will already be highlighted. You can enter the name of the contact by using the number keypad below. You will then push the directional button down once to enter a mobile number, press it down again to enter the home number and then once more to enter a work number.
  • Mar 01, 2011 | Motorola Mobility MOTOKRZR K1 Cellular...
    Have set screen lock to 1 minute, but when I have to use the keypad in the middle of a call (e.g. in response to instructions to press a number), the keypad locks up in 3 seconds or so. I have to...
    ok this model of phone has a sensitive screen and will cause the screen to have a slight malfunction if it is repeatedly touched. you really want that screen locked as soon as it can. you can set the screen to wait a little long but i also have this model of phone and if your talking on it with the screen unlocked you will scramble the calibration on the screen. to repair the calibration you go to the four little dots hit it go to the settings wheel at the bottom right. ok now go to more . go to touch calibrations at go thru the calibration of the touch screen it may tell you that your off a few times but dont worry this is normal. continue thru the steps and save when you feel you have it set to your liking.
    Nov 10, 2009 | LG Vu CU920 Cellular Phone
    Samsung SGH D900I- cannot turnoff keypad sound
    The steps are outlined in the article below:
    D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
    To change the dialing display font type follow the steps below:
    1. From the standby screen, press the left soft key for Menu
    2. Select Settings (9)
    3. Select Display Settings (3)
    4. Select Dialing Display (6)
    5. Select Font Type (1)
    6. Highlight either Normal or Theme, using the navigation keys
    7. Press the left soft key to Save the Dialing Display Font Type setting
    To turn off the keypad tone follow the steps below:
    3. Select Sound Settings (4)
    4. Select Keypad Tone (2)
    5. Highlight Off, using the up navigation key
    6. Press the left soft key to Save the Keypad Tone setting
    Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
    Harris TS22 keypad problem
    Try and Get the Unit tore down to where you can look at the bottom of the keypad. you may have water or something between the board and keypad. I recommend cleaning with isopropal alcohol and q tips. See if that gets you any where
    Jul 09, 2009 | Fluke Networks TS22A Test Set With Speaker...
    Cant hit an extention number or option number on voice mail.
    once in call there an arrow i beleive it will bring up the keypad, speaker and mute. i think its a arrow or there is an icon once you call jsut try any of them there. i dont have my phone handy with me right now.
    Apr 07, 2009 | Dual Electronics CECT P168 Cellular Phone
    My nokia 5300 keyboard are not working when i press them
    1. see the keypad membrane if it is have corossion cleaning alignment is a must or replace the flex
    2. pleace hitting the keypad driver on your phone it will not working change it.
    Mar 18, 2009 | Nokia 5300 Grey Cellular Phone
    Speaker going mute
    check insde the board for the speaker nozzels.
    scrath it with a sharp thingy and try again.
    Jan 30, 2009 | HTC Touch P3450 Smartphone
    Programming instructions for used phone
    Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
    To program:
    1. press speaker or lift handset.
    2. press STORE
    3. dial the number to be stored
    4. press MEMORY DIAL
    5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
    6. press speaker or hangup.
    To dial emergency numbers:
    2. press any of 3 emergency quick dial
    To dial stored numbers:
    2. press MEMORY DIAL
    3. press location (0-9 on keypad)
    Does anyone know how to add PAUSE in a stored dial string?
    Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
    Apple iPhone Smartphone Logo
    102 people viewed this question
    Top Apple Cell Phones Experts
    Ekse
    jacobcheatha
    Level 1 Expert
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
