Question about Creative Labs Zen Micro MP3 Player
Stuck on CREATIVE Screen
Haven't dropped the player or anything, battery was totally dead yesterday, hadn't been used in a while, plugged it in and it to USB and worked fine, the organizer popped up and could bring all songs up. Today, I can't turn it on at all, unless I take the battery out, then it starts and then just stops with Creative logo, can't turn it off, unless I take the battery out and the organized doesn't recognize that is plugged in. Any answers?
  • 1 more comment
  • moncapitan Mar 13, 2008
    Im Experiencing the same problem as Simma7, stuck on CREATIVE screen. A couple of times when battery was out long enough a recovery screen came up so i scrolled to re boot but nothing happed & was getting frozen out again. Would love to know the solution.......Ade
  • s2mmy Apr 04, 2008
    My problem sounds the same as this please help
  • Sim Simma21 May 05, 2008
    I had the same problem.
    This is what was on the Creative website
    "Player Freezes at the Creative Logo
    • Corrupt data on a player can cause the player to lock up
    • Format the player to remove any files containing corrupt data
    • After formatting the player, re-transfer music back to the player
    Step by step instructions for formatting a player
    1. Detach the player from the PC and power the unit off.
    2. Remove the battery.
    3. Move and hold the Power button switch towards the power icon.
    4. Re-insert the battery into the player.
    5. Release the Power button when the Recovery Mode appears.
    6. Select Format (All) and select Yes to format the player.
    7. After the player has finished formatting, select Reboot.
    8. Re-transfer the tracks to the player. "
    Hope this helps.
Send it in and they will give u a new one!!! (free)
Posted on May 04, 2008
  • 4,402 Answers
Hard drive bad,
' Replace hard drive
Posted on Apr 24, 2008
3 Suggested Answers
  • 4402 Answers
SOURCE: creative zen micro doesn't show so I can transfer
1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Posted on Jan 18, 2008
  • 19396 Answers
SOURCE: Stuck on CREATIVE Screen
Take out battery and put it back in, see if it reset
Posted on Mar 20, 2008
Zen is dead
Sounds like a battery problem - either the battery is totally dead or just needs recharging - note that when the battery totally loses its charge, I believe it is sometimes not possible to recharge it using the usb port and software method (NOTE you MUST have the software installed and running for it to charge this way).. you may have to charge it using the connector to the power adapter.
Sep 21, 2008 | Creative Labs Zen Touch MP3 Player
Mar 20, 2008 | Creative Labs Zen Micro MP3 Player
MP3 un plugged properly and it crash
OK all is well just....Allow unit to run dead.recharge battery.turn on and push reset(small paper clip in reset hole).turn off and back on .should now work.if not format and download new soft ware at
Sep 09, 2008 | Creative Labs Zen Neeon MP3 Player
Creative Zen Vision M - Dead Machine
unfortunately,the best solution is to send it back to creative for them to check it out. this sometimes happens when the player has been unused for too long and battery "under charges", which there is a solution.but seeing as u used it under normal conditions,that cant be the problem
Jun 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen V Plus
Simply let it sit and let the battery run out. When it's totally battery-dead, plug it back in and let it charge. It will be unfrozen when it's ready. You might also want to try sliding the off button down while you hit reset for a quicker version (doesn't always work)
May 30, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v problems-frozen
there is a restart button on the bottom but it is a very small hole so maybe use a toothpick to push the button
Apr 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
My creative zen v has totally blacked out
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Dec 17, 2007 | Creative Labs ZEN Vision:M Digital Media...
Dropped Creative Zen Micro 5GB
needs new hard drive
Nov 17, 2007 | Creative Labs Zen MicroPhoto MP3 Player
ZEN V Plus frozen on creative screen
you might need to format the player by holding the play button as you press reset, this will bring up the options to reset of format the plkayer update firmware etc etc.
Oct 02, 2007 | Creative Labs ZEN V Plus MP3 Player
hi look in "Self-help Resources" fro a driver upgrade -see if it works if not look for support good luck
Apr 19, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen Micro MP3 Player Logo
466 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
