Maytag washer Model # LAT9206BAE, Serial # 23002379WB I bought the washer in the fall of 1998 but my husband thinks it is an older model than that. The back doesnt come off, just a small circle you can remove. He had it laying on it's front and took off the bottom. Lookin inside with a flashlight you can see some sort of brown spatters all around inside the machine.
  • twbrx7 Apr 25, 2008
    I have the same washing machine and it's leaking at the bottom of the unit. I have check all hose connects and I shined a flashlight inside the back of the unit and their doesn't appear to be leaks round the hose clamps. I did notice brown splatters all inside the machine. I was wanting to take the front cover off to inspect the machine. What do you think??
    President:
  • Washing Mach... Master
  • 2,651 Answers
The front panel is removed on this model for acess, pop the top up and back by using a putty knife or a thin ***** driver. theres (2) clips that will release the top a few inches in from each sid( push w/ tool and the will pop. tip lid back and there should be 2 screws to release hte front panle for better look. if your seeing brown oily splatters around inside oc cabinet that would be a transmission problem(10 year+ old machine not worth repair).never stated what problem with machine is though
Posted on Mar 11, 2008
How do I open front panel of Maytag washer ?
2 screws at bottom of front remove. Then pulling from bottom towards you until the clips at the top of the front panel clear the top of the machine.
Nov 20, 2016 | Maytag Washing Machines
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
Washer makes loud noises
Make sure all the guides and rollers that support the barrel are in the correct place and did not fall off or brcome displaced. You should be able to search for the schematic for your model.
Apr 01, 2012 | Maytag Washing Machines
How do you replace a motor on a maytag neptune front loading washer
I will try first to replace the motor controller if is a modern washer. if is it a older model there is a kit that includes the motor and controller because of change in production at maytag the old part are no longer made. in your case looks to me you have the newer model. I think the part# is 22004045 for the controller. good luck to you.
Feb 06, 2011 | Maytag Neptune Washer
Maytag washer leaks water from bottom
I would remove the hoses from the pump and use a flashlight to look into the suction port. Check for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no blades missing or broken and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just a clogged pump or jammed impeller. If you can find no fault with the pump, then it could be the tub seal, but I would check the pump first. Very sorry for your trouble and I hope this helped. Best wishes.
Sep 01, 2009 | Washing Machines
Maytag washer lat9206bae drum will not spin switch motor pump ok belts smoke but drom pulley frozen
hi thanks for the question looks like you have a bearing problem the dru wont turn its an expensive repair for that model of maytag they were not a good model thanks for the question the appliance doc
Sep 26, 2008 | Maytag Washing Machines
Model and serial ##
I did finally get a working phone # for support from Maytag and thanks to her and my clever husband- did locate the HIDDEN #'s. She also recommended using the Affresh tablets to see if that helps, but could not confirm that there were any brushes catching lint or that it needed to be cleaned.  MODEL #  MAH3000DAWW front loader
Apr 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
