How do i changs the resolution on my monitor it is mt-ni-dylm2286 22'tet lcd monitor
    President:
  • 2,351 Answers
Open control panel, open display. Click the settings tab. Click the Advanced button. Click the Adapter tab. Look down & to the left you'll see List All Modes button, click on it.
The modes box opends. Choose your display resolution.
That's it. Click ok, than click Apply. All done
Posted on Mar 11, 2008
SOURCE:
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
if the monitor has more than 1 source then make sure it is in the correct one. make sure the cable is fully inserted in the monitor and Pc. try another monitor to rule out a graphics card fault on the PC
Aug 02, 2010 | Soyo MT-NI-DYLM2058 Monitor
I do drawings in Autocad and Photoshop on my 24" soyo topaz s
to adjust the setting on your monitor follow this steps:
right click on the desktop-properties-click Settings Tab-here you find the Screen Resolution then you can adjust it how you want then click Apply and you're done.
Dec 15, 2009 | Soyo MT-NI-DYLM2058 Monitor
My TFT LCD Monitor, serial #MT-NI-DYLM2286 produces a light pink backround, but prints clear. Is there some way to return the monitor to a clear white backround?
rjmusvi, Sometimes the VGA connector at the rear of the PC needs to have it RESEATED 4-8 times to see if it returns the screen to NORMAL colors being displayed on the LCD panel!!! Do this with the POWER OFF to both PC and LCD monitor!!! Also check to see if any of the pins in the monitor to pc plug are bent or pushed down into the connector body. 12fixlouie on fixya
Dec 03, 2009 | Soyo Computers & Internet
Weird characters on monitor, cannot log-in
Well, either the monitor is messed up and trying to display a message like "No Signal" or the monitor is set for a different language.
What happens when you press the menu button on the monitor? Change you make changes?
Nov 18, 2008 | Computers & Internet
Monitor resolution conflict
Install the Drivers for your New Monitor and then try increasing your resolution. If fails to solve, contact your Monitor Vendor (Seller).
Sahaja Yoga is FREE OF CHARGE and is the MAHAA YOGA.
Apr 23, 2008 | Acer AL1916W 19" LCD Monitor
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Open Questions:
Computers & Internet Logo
69 people viewed this question
Ekse
Alun Cox
