Question about HP Pavilion ze4220 Notebook
Harddrive I have installed hard drive. how do i make it work?
Driver of printer laserjet
Posted on Mar 11, 2008
Bios no longer detects the harddrive
Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
Jan 14, 2014 | Toshiba Satellite M55-S331 Notebook
My computer cannot recognise the hard drive
Are there any other harddrives installed on the computer...or is this a new harddrive...
If it's a second harddrive...then you have to set the jumpers accordingly...if it's a new harddrive...it should of came with a Cd and or floppy (depending on how old your computer is). You need to install that cd first, so it can tell your bios/cmos that there is a new HDD and the software will tell it to recognize it. Let me know
Dec 02, 2010 | Maxtor Hard Drive
My Portable hard drive will only work on 1 computer
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 03, 2010 | LaCie Computers & Internet
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Won't boot up
Buy a new harddrive and install a new OS on it
make sure your old harddrive is disconnected
after the new hard drive is working properly then reconnect your old harddrive and
u will have all your files back unless the old hard drives crashed completely
Oct 18, 2008 | Gateway GT4022 PC Desktop
I WANT TO INSTALL MICROSOFT WINDOWS XP 2007....AND IT'S KEEPING ON SAYING I SHOULD INSTAL HARD DRIVE......HOW CAN I GO ON ABOUT IT.... MY EMAIL IS.... olyholly001@yahoo.com
Also - if it is telling you to install a hard drive - then your bios is not reconizing that you have a hard drive installed. Go into your Bios to see if your hard is listed. if not - you need to open your computer to make sure all the connections are correct. if this doesn't work, you may have to buy a new hard drive.
Aug 09, 2008 | Compaq Computers & Internet
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Install hard drive
Dear PBRIM ,
First of all you have to format new Hard disk then you have to install the Operating system and drivers on it then it will be work.
Cheerup and Be Happpy always
Mar 11, 2008 | Computers & Internet
Help me ! Lacie ED Disk Ethernet 10/100
if you are using (sata)harddrive dont install windows 98.i have a solution now before connecting your harddrive change the jumper to the slave (for single harddrive and single cd-rom or combo drive).it will work.plz install windows xp (service pack 2) or windows vista these are good versions for all!
Dec 07, 2007 | LaCie (300770) 250 GB Hard Drive
HP Pavilion ze4220 Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
