Polti vaporetto 2000
My POLTI will heat up but not produce steam. What could the problem be please?
regards
D Davies
  • soupdragon Mar 11, 2008
    I've sorted it out thank you. I put some Kal Stop (5ml) into 1500ml of water into the Polti, let it heat up and it's broken down the limescale build-up on the solenoid. Hope this helps anyone else having a similar problem. Have a good day ;-)
  • soupdragon Mar 12, 2008
    You can purchase the Kal Stop from Polti. It's well worth the money. Mine came with 2 free phials.
    Problem Solver:
  • 17 Answers
I added a phial of KalStop which is biodegradable to 1000ml of water put it in the tank, turned on the appliance and let it come up to temperature. Then I operated the steam switch on the wand and voila after a few more spluttery spurts, it started producing steam again and even better than before. Hope this helps anyone else having the same problem and before throwing out the Polti or paying £79 to have the solenoid cleaned by the manufacturers.
Posted on Mar 12, 2008
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
Lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti spare parts
i have a 950 and it does not heat up any more . the red light comes on but thats it
Feb 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam polti 2001r, heats up clicks, but no steam!!!!!!
the solenoid valve isn,t operating when you pull the trigger. It is caused by either the coil has burnt out on the solenoid or the valve itself is stuck
Nov 06, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Washing Machines Logo
664 people viewed this question
Top Washing Machines Experts
