Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool ED5LHAXMB11 Refrigerator side by side
Ice maker stopped working...I can still get water out of the dispenser. The tube that drops water into the ice maker is not frozen. The lines on the back of the frig are not kinked/knotted....please help. The frig was mfg in 01/06.
  • 1 more comment
  • Anonymous Mar 17, 2008
    water runs but ice maker not working. whirlpool GS6NBEXR side by side refrigerator.
    Email to me direct Islandcoolingltd@yahoo.com.
    Thanks much ,
    guess from Anguilla.
  • twobob Mar 28, 2008
    water in village was turned of last week for a few hours, when water pressure was restored the water dispenser worked but the ice maker didn't, We have tried all the troubleshooting as described in the manual, Checked the filter which is new. Turned the fridge of for one hour. All to no avail. Please help. The fridge was purchased in December 05 and evrything else works fine.
  • djrdplummer Aug 09, 2008
    Ice maker stopped working. No frozen lines...no kinks.Infared light is blinking constantly. Water dispenser is working. Please contact me at djrdplummer@att.net
    Thank You !!
    Problem Solver:
  • 8 Answers
Check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Posted on Mar 22, 2008
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool conquest g56sha not making ice
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
This will help. Thanks. Helpmech.
Oct 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker has quit working where do I begin?
Aug 28, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
My ice maker has stopped working, the water continues to dispense thru the door yet the ice has stopped
Most likely the water control valve on the rear of the refrigerator is defective for the ice maker side of the valve. Try filling the ice maker with tap water and let freeze. If the ice drops and cycles and does not refill then the water valve is the problem. If the ice maker does nothing when you try this the ice maker is the reason. Send me your model number and I can tell you the parts that need replaced. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
Check supply tube to see if frozen or blocked using Q-tip or feel to see if frozen. if Frozen, hold up clear glass with heated water placing tube in hot water. Hold till ice in tube melts. Clear glass will allow you see ice slip out.
Jan 19, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
301 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
