Question about HP PSC 2410 All-In-One InkJet Printer
Glass cleaning the underside of my printer glass needs a clean as it has a streak on it
  • 1 more comment
  • weedchevy Dec 16, 2008
    Glass has marks from the scanning optics going back and forth. I need to know how to access the glass.
  • Anonymous Mar 14, 2014
    it is making 3 black streaks and we cleaned
    glass and lid
  • Anonymous Mar 15, 2014
    how remove glass to clean underside
First remove scanner cover look at how it is connected in hiddle is raised piece dont rember if you push towards front or back of printer its been awile scince iv had to do this one on left side of scanner is two screws screws on right are under control panel to remove this carefully take off cover over numbers by putting small screwdriver at bottem of lcd and lift up on cover over buttens after this is up find small slot on very front middle where this cover was if you press down carefully and slide control panel forword to release do slowly two ribben cables attach it remove carefully then remove all screws with T-10 driver glass and outer plastic should lift do not damage ribben cables after glass clean put cables back thru slot carefully replace screws reattach control panel cables look at how it slides back on
Posted on Mar 16, 2008
Horizontal lines/missing print occurs on my pages. I have tried to reboot the printer, but the printing issues remain. Do I need to clean the print heads?
Follow these steps to make it work... TIP: Focus on the printer it self. make sure that it can copy (b&w and color) fine.
If your done reseting the printer go to the next step Solution #2 Clean the All-in-One and make a blank copy Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the power Button to turn off the product, and disconnect the power chord at the back of the printer.
  2. Open the scanner lid, and remove any originals from the scanner glass.
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth.
Step two: Clean the automatic document feeder ADF
  1. If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
  2. Locate the ADF frame to the left of the white underside of the scanner lid.
  3. Press the ADF frame release.
  4. Unhook and remove the ADF frame.
  5. Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
  6. Use the dampened cloth to clean both sides of the transparent film, and the white strip in the center of the ADF frame.
  7. Clean the ADF frame.
  8. Re-Install the ADF Frame
Step three: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
  • If the copy is clean, there is no need to continue troubleshooting.
  • If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. Contact HP's Printers support department @ 1-800-474-6836
To view this steps w/ images click on this link Good luck! :)
Feb 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
My HP3030 scanner glass is dusty on the underside
Yes you can. Just be careful not to force any movement of the scanner lamp. Be gentle. Otherwise you have nothing to fear.
Apr 08, 2009 | HP LaserJet 3030 All-In-One Printer
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Streaks when scanning and the glass needs cleaned how do I get in to clean the glass on the underside
Here's a link to the instructions for opening the top of the scanner:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
BG
Oct 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Dirty glass inside scanner
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove the it is easy to put it back together and you do not have to worry about breaking anything.
Once you have access to the underside of the glass I use real windex and newspaper. With the newspaper you get a streak free shine with no lint particles. If there is dust inside the glass there is most likely dust on the scanners optics. Gently clean them the same way. Be gentle when cleaning the scan bar optics. They are not extremely delicate but it will break if you apply too much pressure as it is a long thin piece of glass.
When you put your scanner all back together it will scan as good as new and all the little black specs and streaks will be gone in your scans. I've done this 100+ times and it works every time. If you need help feel free to contact me an I will walk you through it for free.
I hope you found this info detailed enough to fix your scanner yourself, But If you need some help or moral support feel free to E-mail me and I will even call you for free. Make sure to say what you need in your E-mail as I fix a lot of things for people.
George
Jul 24, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cleaning the inside of Lexmark 5150 scanners glass
To clean the glass on the inside you must disassemble the unit so that you have access to the underside of the glass. If you save all your screws and are careful to lay things out in the order you remove them it is easy to put it back together and you do not have to worry about breaking anything.
George
HP photosmart 2710 dirty glass
hi,
no way.... u cannot clean the underside of the glass... u can clean the glass using a lint free cloth....
thanks and regards
agnel
Dec 30, 2007 | HP Photosmart 2710 All-In-One InkJet...
How do you clean the INSIDE of the scanner GLASS???
The service manual is avalable free through Emule:
ed2k://|file|Canon%20PIXMA%20MP750%20MP780%20service%20manual.pdf|1416152|F054D74C11BE5EEAF2F6D203362303DE|/
Dec 19, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
394 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
