Question about Maxtor Hard Drive
Hard drive files recovery
I have a problem with my HDD. In my PC, old HDD is corrupted and i cannot access my files. i install windows on second HD and it is now master. i set old one like slave. when i try to bring windows up, first i have to check bad HD,and then i can start windows, but i have to wait to much. when i start windows, i cannot access my files on corrupted HD. is it possible to recover files from corrupted HD and how?
  • djole54 Mar 11, 2008
    No, it is not mechanical damaged, i tried to access with some DOS tool (readntfs) and it is works.i can pick some data up. but it is very slow.is there something faster?
    no, it is report status BAD
  • 13,434 Answers
If the drives internal mechanics have failed then theres not much to do. You can try to take it to a professional datarecovery.
It will cost you.
Posted on Mar 11, 2008
  • Ekse Mar 11, 2008
    if its Very very slow then the drive is failing, does smart report good status?
    There are a few programs witch can recover data but most of them arent free.
SOURCE:
Hard disk problem in hp pavilion p6 2358in
HP laptops LOVE to have hard disk problems. Here’s how to fix it: DON’T EVER BUY HP.
In reality, at this point it’s too late so here’s what you need to do:
1. Get an external hard drive. You only need it if you want your files.
2. Boot up your PC in recovery mode and get to command prompt. Instructions specifically for this can be found here: http://www.dummies.com/computers/operating-systems/windows-xp-vista/how-to-get-to-the-recovery-console-in-windows/
3. Copy your files to the hard drive by running the following commands in this order:
diskpart
xcopy C:\ D:\ /E /H /K /O
Make sure this doesn’t fail.
Make sure that your files are on the new drive has the files. Then, you’ll need to make a Windows recovery media. Get a working Windows computer and a flash drive making sure it’s empty and has no important files. Then, press the Windows key and type recovery. Find Create a Recovery Drive and click it. Go through the steps and turn off the broken HP. Boot up the HP while holding down on Esc. Then press reset my pc. Make sure your external hard drive is unplugged. You can go through these steps and you should have your computer reset. Set it up like you did when you first got it. You can plug in your external drive then. You will have all of your files on the external drive and you can move them back. Good luck! ;)
Dec 29, 2017 | HP Computers & Internet
Recovery of my r51
The O.S is corrupted and you want to format the HDD of your Laptop.before formatting backup your all data,so that you can easily format and install new O.S.
Laptop Hard Drive Recovery
Laptop Data Recovery Laptop Hard Drive Recovery
Feb 14, 2014 | Lenovo ThinkPad R51
"file or directory is corrupted and unreadable"
that happens when USB is disconnected. Might need to reinstall o/s drivers on pc or on hdd then do data recovery.
May 16, 2012 | Iomega Computers & Internet
Error message that says Drive is not accessible. The file or directory is corrupted and unreadable.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Hi when try to boot my laptop it says hp 3f0 and hard disk not exist. Can i get back all my files/pics without before creating a partion recovery? Can you please set me instruction and by the way...
Hi mohamed04,
I recommend you to perform an HDD self test so we can understand if you have a faulty HDD or just a Software problem caused by any windows update or virus that might have corrupted your windows boot file.
For performing an HDD self test you should turn on the unit and when HP invent logo appears press " ESC " key, then you will have access to other menu where you should select option " F2 - System Diagnostics" and then " F4 - Hard disk Test" . After process finishes it will provide you a message with " success" or #xx Fail".
You need a new hard drive and install fresh windows operating system. Maybe after that you can try to put your old hard drive to external enclosure hard drive and try to recover your computer will recognize the hard drive. Hope this helps,
HRH
Jan 05, 2011 | Computers & Internet
Recover data from an external hard drive that doesn't work
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Dec 30, 2009 | Computers & Internet
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
No boot device available - strike F1 to retry boot, F2 for setup utility after getting the blue screen of death
Your PC is telling you that it cannot recognize your Hard Drive. You need to order a new Hard Drive. They are very cheap. Then you will need to re-install Windows. All of your data may be lost, but you can bring your Hard Drive to a data recovery center or PC Store to see if the data can be retrieved.
Hard Drive is probably dead so you will need to purchase a new one.
Sorry and Good Luck.
Oct 15, 2009 | Dell Dimension 8400 PC Desktop
WD My Book not displayed in windows explorer as drive letter
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Hard Drive Data Recovery
With file recovery program like asoftech data recovery, hard drive data recovery becomes an easy job. download the program from
Dec 26, 2007 | Computers & Internet
Maxtor Hard Drive Logo
104 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
