Question about Refrigerators
Refrigerator condensation I have a Kenmore Coldspot Model 70262990, I am starting to see water/ice buildup on my shelfs every couple of days. I have tried to adjust the temperatures for the freezer and refrigerator. Rearrange the food and I have cleaned the compressor area for better airflow. Still see build-up. Any suggestions?
  • 2 more comments
  • jcarc12 Apr 04, 2008
    WATER POOLING ON BOTTOM OF REFIGERATOR UNDER DRAWERS
  • Schiele Apr 14, 2008
    Kenmore Model # 70262990
    Serial # EK3329568
    Lots of water on the glass shelves, in the bottom bins and in the bottom of the refrigerator which also ices over. To no avail, I've moved items around in the fridge and freezer, checked the seals and made certain the ice maker (not hooked up) lever is in "off" position. Please help!
  • jjc6676 Sep 21, 2008
    My Freezer works just fine, The bottom half, refrigerator, does not. It is as if it gets really cold, freezing, then kicks off and gets really warm, enough to form condensation on each tower from items suchs as water bottles and soda cans, which will leak down to the bottom and on top of anything in its path. Then sometimes when I open the fridge, i will see ice! So all the condensation freezes, it is back and forth with these two things, im not sure what the issue is
  • slong320 May 24, 2009
    I have a new glass door wine refrigerator. Water condinsation constantly forms on the glass door, builds up and drips to the floor. Is there anyway to prevent this?
  • 3 Answers
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Posted on Apr 26, 2008
    President:
  • Refrigerators Master
  • 2,651 Answers
Check for doors closing properly look around perimeter of entire door gaskets, warm air is getting in somehow and condensing
Posted on Mar 11, 2008
Kenmore model 253.7419240p water pooling under crisper
Do you see any ice buildup on or behind the back freezer wall?
Oct 31, 2012 | Kenmore Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Water drips from the freezer into the fridge.Upon disassemble, there is ice buildup under the coils. kenmore coldspot model #71184101
The defrost timer or the defrost heater element has probably failed. Go to the link below and enter your exact model number; you should find a line-drawing illustration and parts list for your fridge that you can use to locate these items and normally also determine how to remove or install them:
Sears PartsDirect
Apr 08, 2011 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
4,349 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
