Question about Edirol UA-4FX External Sound System
I have now sound in my computer
Can you tell how to get my sound back on after i have cleaned my computer?
    Master:
  • 351 Answers
Dear intermilan,
let me know the model of your sound card & your Operating System ,so that i can provide you the proper driver for the same.
Cheerup And Be Happy Always
Posted on Mar 11, 2008
My intex speaker 2.1 woofer is not working properly the sounds like buuurrrhhhh comes out from it tell me the solution
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Jul 01, 2011 | Computers & Internet
When I put the power on the oven heats up and the elements won't go out. It seems like the system is stuck inself cleaning mode. How can I clear this? The model # is 38HW 6JTV.
the model number is CER3725AA but you left out one letter at the end.there's a computer board in this also the clock assy. everything runs through this,it sounds like the clock assy.is bad or you can check the sensor first but it sounds like the clock.on older machines this would be a runaway thermostat but the computer does this now.first you can try shutting the power off to the machine for 5 minutes to see if it clears the computer,sometimes they have to be restatrted just like your house computer,if that doesn't help you can try changing out the sensor,this tells it how hot it is in the oven,there should be a tech sheet on the back of the top console or down near the draw,it will tell you how to read out the sensor with a meter,i think it's 1080 ohms but the sheet will tell you,if the sensor is good it's gonna be the clock assy.the part numer is 5701M829-60 and it's 180 dollars.the sensor part number is 12001656 and it's around 45 dollars.good luck.
Apr 13, 2011 | Magic Chef CER3725AA Electric Kitchen...
I recently cleaned out my computer and purchased a new power supply and video card. Now my sound doesnt work and i think it might be a jumper or something on the motherboard. the computer tells me to plug...
It could be a jumper need to move or set a different place, but that sounds like it's the card not install properly. If the computer or motherboard not reconizing the sound card then it won't work don't care what you try to do!
Halla back @ me!
KJ
Apr 11, 2010 | HP Pavilion a6110n PC Desktop
My computer beeps but it beeps like a robotic sound..
exchange the memory in different slottt. clean the memory slotss and clean the memory with pensil eraser only the gold pinss., then insert them back in, if u can take the fan off and cpu check if its burned or anything then insert it back..
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
NO SOUND AFTER COMPUTER WAS CLEAN OUT FROM A VIRUS
The realplayer need to be downloaded now from their website
Dec 14, 2008 | HP (400745-001) Sound Card
Sound device
If your sound device is removable, like PCI Card, try to remove the PCI Card and clean the connector with dry brush, then place it firmly back again.
If your sound device built-in on your motherboard, please re-install the Device driver provided by the Motherbard Driver CD.
-mrsolution
Jun 11, 2008 | Computers & Internet
My computer is not turning on. I just wanted to know if it is a problem with the motherboard or simply the HD. When I press the turn on button, the computer turns on, the cooler works, but i can't see...
Check if you can hear any beep sounds, if you hear a long continuous beep sound, remove the Memory on you Motherboard and clean it with a dry brush then place it back again, be sure you place it as how you remove it, make sure the lock knob on each side of the memory slot firmly locks. If you hear a very short continuous beep sound remove the Video Card then clean it with dry brush and place it back again, make sure it sits tight on the slot.
Jun 11, 2008 | Toshiba Computers & Internet
Sound card
You probably uninstalled your sound card driver.
Here is how to check.
http://support.microsoft.com/kb/133240
Nov 17, 2007 | ASUS A7S333 Motherboard
Sound card
you can try removing the card via device mannager
then reinstalling it
or possibly roll back the drivers
can you tell me what make the sound card is ?
what operating system you are using ?
Nov 10, 2007 | Audio Players & Recorders
Edirol UA-4FX External Sound System Logo
14 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
