Question about Philips 60P8342 60" Rear Projection Television
Philips tv how can i fix my tv its come on for about a minute than it cuts off
  • beeds Mar 11, 2008
    if i have the manual how can i find out is that the problem
  • Philips Master
  • 8,617 Answers
Your TV is going into protective shutdown. Usually from a small part malfunctioning such as a diode or transistor. But you would need the service manual to actually diagnose this
Posted on Mar 11, 2008
  • Sonny Berry
    Sonny Berry Mar 11, 2008
    you will have to go into the service manual and check the start up voltages as they enter the set. The manual will show you which components to check for standby power and start up voltages.
I have a Philips 42pf7421d/37 lcd tv having problems. When you first turn the tv on it seems to work perfectly fine. About 5 minutes later my picture cuts out and I get a scrambled screen. Turn it off and...
First, you need to make sure all of the vent panels on the tv are clear of obstructions. Heating may be causing the problems. Next, get a hold of a clean, dry source of forced air and blow out the inside of the case and the internals of the tv.
Jan 22, 2013 | Televison & Video
Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Jan 25, 2010 | Philips Televison & Video
Philips DLP TV purchased
The small signal board is the problem with the set replace that and the set will be fine. the small signal board is the video processor..
Jan 12, 2009 | Televison & Video
Magnavox vcr/dvd
cold solder that the common problem of tv so try to re solder the power supply or the jungle & horizontal section
Sep 22, 2008 | Philips Magnavox 27MS343S 27" TV
50p8341 on-screen menu
05/09/08
I called the Philips help number (1-888-PHILIPS) and the tech had me turn off the tv and then unplug it from the outlet, wait 1 minute, then plug it back into the outlet, then turn the tv back on. It reset the menu memory and it is now back in the middle of the screen where it belongs.
Feb 23, 2008 | Philips 50P8341 50" Rear Projection...
Sound cuts out every so often when using Coax Digital In
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
Philips 60P8342 60" Rear Projection Television Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
