Black vertical line
When I turn on my television I just get black vertical lines on the screen. The lamp as been replaced recently, so I don't think it is that. Any suggestions?
    Scholar:
  • 135 Answers
Hi there!
My guess is that there are loose solder points on the Matrix circuit. Best to resolder all points on board, especially the surface Mount ICs. If not familiar with soldering refer to service technician with the right equipment to do the job professionally. Toshiba Rear Projectors are common for this. Good Luck, Jus004
Posted on Mar 11, 2008
SOURCE:
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
Recently bought a Dynex flatscreen 32 inch tv and noticed faint lines moving up the screen. Some channels it is really noticable and others not so much. Tried switching out the coax cable cord and that...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem..
Sep 12, 2011 | Dynex Televison & Video
My tv wont turn on the light on the power button blinks and the lamp turns on in the back but the screen dont light up
check if crt screen voltage correct (g2) try to adjust screen settings at flyback transformer and monitor if g2 response, some model if vertical ckt down monitor have black signal only can determine if screen adjustment knob in flyback transformer turn increase. vertical line appear.
Mar 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
Sets of vertical lines
why do you bother with the free service. Do you just keep sending email requesting money.
Jun 27, 2008 | Samsung HL-P6163W 61" TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Ekse
