Question about Dryers
Still having start up problem...
I removed the motor and had it tested, the guy blew out the dust and put power to it and it ran, no problem. I brought it home and hooked it back up and it worked. What could cause an intermittent start up problem like this? I'm worried that I will put it all back together and have the same problem again...any help would be appreciated!
Thanks,
Mike
  • mzambakk Mar 12, 2008
    Finally fixed! I jumped out the door switch, ran the motor and wiggled the connector, sure enough the motor stopped and I noticed a small spark inside the connector. Tightened connections, goog to go for now. Thanks for all your help!
    Mike
    President:
  • Dryers Master
  • 2,651 Answers
???? got me. coulda been a build up of lint around the copper windings, although the motor starts on the bench under the tension of belt perhaps too much?. and if there was that much lint built up in and around it I would look into reventing, or at the very least cleaning out your vent system
Posted on Mar 11, 2008
My girlfriend recently blew the freeze plug located on the back of intake manifold and I believe it was ran very hot. I replaced it and car started but ran rough, so I killed the engine and tried starting...
when a motor has been cooked ( run with out water ) the rings loose tension , the pistons score the cylinder walls, the head cracks or warps and the head gasket generally blows. In mechanical circles , your best option is a replacement motor either from an engineering rebuilding shop or a good unit from the wreckers.
Feb 07, 2015 | Cars & Trucks
John Deere 265 starting problem
To start ensure that is not a carb problem, and that the engine is not chocking because of incorrect carburetor settings. The carb should also taken apart and cleaned.
Try also running the engine without fuel tank cap, if engine runs fine replace the tank cap.
if carburetor, fuel filter, tank and fuel lines are ok it may be a faulty fuel pump failing. To test the fuel pump, insert a pressure gauge tool like this in the lines out from fuel pump.
Regards.
Jul 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My dinamap is showing error 950 when i hit the inflate start button. what is wrong?
HI From a Tech Guy,
Your issue is caused by motor over current.
Check the pump motor assembly under the foam cover.
remove torx screw on top.remove cover that has two nipples.
check inside mesh filter/ dust filter. if black is dust.
spray contact cleaner and blow with air. let dry.becareful not to use slovents may damage blue mushroom check valve.reassemble all.test should be ok.
hope it helps
cheers
Mar 12, 2012 | General Electric Dinamap ProCare Series...
Computor beeps
its a POST test beeps. POST = power on start test, it is finding a power issue in your computer, it could be anything but i would start by removing one part at a time see if the computer starts if nothing changes put it back do this one by one see if it anything inside (start with cd drive, then hard drive then video card) after those its either one of 2 things either your power supply is bad or your motherboard is dead/dying (most likely your motherboard in my experiences)
Nov 15, 2011 | Dell Dimension 1100 PC Desktop
Honda ES6500 blows 15amp fuse as soon as the key is turned to "ON" tested starter with a jumper wire, works fine. Took the control box apart found nothing unusual. Removed ignition switch found...
hi
I think the problem is on when the key is turn to rotate and to engage the starter motor and it at this point that the cable curring the current on to the starter motor it then the fuse gets blown , in my opinion this cable is shortening across the chassis causing the fuse to blow, or when it get to the starter solenoid a faulty solenoid absorbs accessed electric current causing the fuse to blow
Jan 16, 2011 | Honda Electrical Supplies
Air conditioning and blower stopped working, all fuses checked good.Is there a common feed to these two circuits?
The answer is that there is dirt dust and fuzz built up in the brushes of the blower motor. Had to figure this one out myself. Remove glove box, carefully disassemble bottom of blower motor, remove brush cap and brushes clean up mess and reassemble. Not for a novice but if you're a thinker you can figure it out. Mine has worked every time since. The Pontiac guys had no clue wanted to replace motor.
May 21, 2010 | 2004 Pontiac Vibe
Wiper fuse blows as soon as you insert one
first....be sure the fuse is the right ampage. second...if the ampage is correct, and it still blows, do the following. Disconnect the ground-side of your battery. Attached test lamp to ground-side of battery. Take probe end of test lamp and touch anypart of the motor body frame. If the test lamp (DOES NOT LIGHT UP), you have an electrical short. Recommend OBD (On-board Diagnostic) analysis test.
Apr 25, 2010 | 1998 Subaru Forester
Blowed head gasket
have a block test done, this way you will know for sure,it not costly,
Dec 13, 2009 | 1992 Chevrolet Suburban
Hi, freezer is cold at bottom , circulating fan is not working.
Hi Guys, I tested fan removed(to 240vlts) neg- pos to wires+earth to mount bracket, and found to be working, reinstalled and found power - active to both wires??fan cut out (defrost mode)activated by timer control, my timer control ( bottom rear near motor) has a knob, so i turned it and fan started,continous turning knob ran thru all cycles defrost,fan start, etc: obviously timer control was faulty, To save frozen goods , i set control to run and installed a power point timer to cycle freezer till new switch arrives, taking the place of faulty controller...
Oct 23, 2009 | Electrolux Freezers
Open Questions:
Dryers Logo
37 people viewed this question
Top Dryers Experts
Marvin
Marvin
