Question about Acer Aspire 5610 Notebook
Black screen Screen goes black after about 2 seconds,if I put in hibernate mode for a while and then disable I will have regular screen for about 2 minutes then goes black again.I have not spilled anything onto laptop,but this problem seemed to start after burning some songs to cd.I have read about a possible burned capacitor,or bad inverter,a vista program bug.I took the memory compartment door off and looked inside,but I do not see anything loose or burned out.Computer had basic warranty of 12 months,and this happened on 13th month...dummy me !!
  • Acer Master
  • 19,396 Answers
First check well that is not a windows bug. To do so try starting computer in safe mode and do system restore, or do a backup of your files and do a complete recovery if you can. If it is not a system problem then it must be one of following.
Remove battery and disconnect laptop from outlet. Connect it back to outlet with no battery in and check, if it works, then it was the battery.
Then start the computer in bios and leave the laptop on with bios page for one hour or so. If it turns off then it is probably an overheating problem related to malfunction of CPU fan. In this case the fan must be replaced.
If none of the above then most possible cause is a faulty motherboard, in this case you will need to find a spare laptop or motherboard of the same kind (check ebay).
regards
Posted on Mar 11, 2008
  • 796 Answers
What operating system are you running??
  • 1 more comment
  • isaac johny
    isaac johny Mar 11, 2008
    have you tried it with any other operating system in the same laptop??
  • isaac johny
    You may check power settings in control panel and see if somehow the
    settings for your screen are set to turn off or the power settings
    program has been corrupted for some reasons.
  • isaac johny
    problems may be
    1 Device driver problems
    2.Device interrupt request/DMA/ I/O address conflicts
    3. Graphics problems
    all these can result in randoim shutdown of a PC BUT all can be resolved using device manager.
Sony VAIO VCG-FE770g, turns on automatically after pressing Hybernate or turn-off
Go into power option, select hibernate, uncheck box to the left to disable hibernate, this will free up disc space and get rid of the problem. If that is not an option do a system restore before the update
Jul 23, 2012 | Computers & Internet
I have an E series lifebook. The laptop just got wiped clean because it had a bad virus. I took it to a professional tech and he did the work and also updated windows. the computer was working fine prior...
You can turn Sleep and Hibernate off in Windows but this sounds like it might be your Bios putting the system to sleep. In windows go to power options and turn sleep and Hibernation off but double check your Bios as well for a possible setting there that will put the computer in sleep or Hibernate mode.
Jun 27, 2010 | Fujitsu LifeBook E7110 Notebook
My screen goes black after startup
Try a different monitor, I am sure this sounds overly simplistic to you but, I have seen in my customers have just that, a bad monitor.
If another monitor does the same thing, then you should try another video card. If the video in on the motherboard, there should be a AGP, PCI-e, or an empty PCI slot to put a video card in.
Aug 08, 2009 | HP Computers & Internet
Viewsonic monitor goes black one second after startup screen boots up. Fix for this? thanks
plz log in safe mode and then disable the display adapter from the device monitor then log back normally and check whether problem is solved or not
Apr 29, 2009 | Computers & Internet
Wont come outof hibernation goes to a black screen even upon rest
RESTART IN SAFE MODE.
OR
REBOOT SYSTEM, BEFORE IT BOOTS PRESS
F6 UNTIL YOU HEAR THE BEEPING NOISE, THAN STOP AND SELECT SAFE MODE
THAN CONTROL PANEL AND SELECT POWER OPTIONS
POWER BUTTON OPTIONS
Mar 14, 2009 | Computers & Internet
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
Laptop screen turns black
In Windows XP you can disable hibernation by doing the following:
1. Open Power Options in Control Panel
2. Select the Hibernate tab
3. Clear the checkbox for enabling hibernation
This doesn't work in Vista however because the GUI for Power Options has changed and doesn't offer the ability to disable hibernation. But you can disable hiberation in Vista from the command line if you use admin privileges. Here's how:
1. Press the WINDOWS key and type cmd into the Start Search box but *don't* press ENTER
2. Right-click on cmd in the Programs list and select Run As Administrator
3. Click Continue when the UAC prompt appears
4. Type powercfg -h off and press ENTER
IF this does not help write back.
Jul 23, 2008 | Toshiba Satellite A215-S5822 Laptop
Acer Aspire 5610 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
