Downloading problems I have just recently purchased a roland AT60SL 0rgan (thru your agents here in Brisbane Australia) However in recording my songs to the 3 1/2 inch floppy disc, I find that it is completely incompatable with Windows XP as it refuses to respond to down loading to the music folders Can you help with this problem? I assume that this is a problem to be answered by Roland at no additional cost to me, as it relates to a purchased item.
  • 6 more comments
  • jimmelth Mar 12, 2008
    Additionally I should add 1. The floppy disc is 1.44MB
    2. Roland manual advises that it must be formatted in the organ itself
    3 The recorded files saved to floppy disc are in the SMF format all with the suffix ".mid"
    the unformatted disc is formatted after installing in the disc slot IN THE ORGAN and activating a dropdown screen which says
    "Press to format disc" Then "proceed"
    It takes about 2 to 3 mins. when the sceen then says "formatting completed "
    yes I have copied the files (SMF) but thats the problem I'm getting some sound but only the base pedals. In other words No I can't listen or play. That's why I'm talking to you
    Reading your last question again
    Yes I have copied the files into the desk top
    and I can't play them. I can play them thru the organ
    I get can get the file title but it will not load to play other than the base pedals. This checks with the file title on screen of 20 odd bites. the song as recorded must have a lot more bites than that That is in transferring to the desk top its only "grabing" only part of the recording
    Last Comment by Ginko
    Yes as I say I can get sound but only of the base pedal notes and the rhythm taps.
    so OK its not a problem of compatability.
    But let me assure you I have saved the tracks exactly step by step as required by the owners manual. Incidently I have askes the Roland dealer "Ellaways" here in Brisbane but with no response
    You can access the user manual on the internet.
    Go to www.roland.com----click on roland---then Products---then go to Organs
    Scroll down to details of the AT60SL and down load Owners manual
    Yes I can play back the floppy on the roland organ and plays perfectly after trying to down load to the PC.
    I have been able to record perfectly since the day it was delivered and can still record and play back right now thru the organ BUT NOT THE PC
  • 19,396 Answers
As far as I know AT60SL is completely compatible with any windows version. it uses 1.44MB with standard.mid files.
Format a floppy using AT60SL.
Save some midi in it.
Put floppy in the computer
Open 'My computer' on PC.
Open ' Floppy ' on PC.
If you can see the *.mid files inside the floppy then there is no incompatibility.
In this case you will probably need just a software to play mid files on your pc.
If you cannot read floppy on pc and get an error message or 'floppy is not formatted' message then there is a problem either with AT60SL floppy or with pc floppy.
Test the floppy on different PCs, if it works on a different PC then it is a problem with floppy on your pc.
If floppy formatted on AT60SL give error on all PCs then floppy on AT60SL is faulty and should be replaced. Most common cause is bad or azimuth out floppy head.
regards
Posted on Mar 12, 2008
  • 6 more comments
  • Ginko
    Ginko Mar 12, 2008
    The problem is with computer, not with the organ
  • Ginko
    Ginko Mar 12, 2008
    Can you hear any sound at all from that computer.
  • Ginko
    Ginko Mar 12, 2008
    If you can paly on pc the base pedals track then is not a problem of compatibility. It is something wrong in saving track settings or in the way you are saving tracks.
    Let me see if I can find user manual.
  • Ginko
    Ginko Mar 12, 2008
    It is when you save on roland that something goes wrong, not when you play files on pc. If any other expert can post user manual, that will be great
  • Ginko
    Ginko Mar 12, 2008
    The problem is that your AT60SL has a 7 track recorder on floppy, for
    some reason is recording only 1 track. I couldn't find the user manual
    on Internet. I need to ask tou few questions:
    1)Important: If you play back same floppy we put now on pc, on roland can you hear regular music (all seven tracks) or just bassline?
    have you even been able to record music normally with your AT60SL, I
    mean were you recording normally untill yesterday or last week etc,
    then you started having problems?
    Or you recently purchased the AT60SL and you have never been able to save/play tracks normally from AT60 to pc?
    thanks
  • Ginko
    Ginko Mar 12, 2008
    Then the problem is with your midi reproduction device (sound card software emulation probably) on your pc.
    Go on your pc. Go to start button, chose 'run' type 'dxdiag' into the run program box, press ok.
    It will open Dx diagnostic tool .
    Go to 'music' tab at top of Dxdiag panel on pc. test 'Microsoft midi mapper' selecting it and pressing test and see if it plays a melody (not only bass).
  • Ginko
    Ginko Mar 12, 2008
    Do same test with dxdiag on microsoft synthesizer on same windows, just change selection in box in the middle.
  • Ginko
    Ginko Mar 12, 2008
    If the test did not work then you have to download and install directx and or soundcard drivers (this depend on your pc make and model)
    If the test did work then you can try troubleshooting the problem installing a midi player different from default , or upgrade windows media player.
    regards
    I am posting back here the AT-80SL_60SL_manual for future reference
  • 13,434 Answers
When you have the floppy in your pc.
Try to copy the mid files into your desktop or any other place you want to have them in.
If you can copy the files, but can you listen? or play them.
If not your going to need a codec for that but il provide that
later incase you cant access the files on the floppy, so report back when you have tryed :)
    President:
  • 1,950 Answers
How are the floppy discs formatted?
  • 2 more comments
  • Damen Wong
    Damen Wong Mar 12, 2008
    What exactly happens in XP when you put the floppy in the drive?
  • Damen Wong
    Just download and install Apple Quicktime Player. It can open and play .SMF files.
    http://www.apple.com/quicktime/download/
    Keep us updated.
  • Damen Wong
    Just install quicktime and it will play your files.
  • Damen Wong
SOURCE:
Who is the best real estate agent in Sydney (or Brisbane)?
Yo mate! First of all, welcome to Australia, I hope you'll have an amazing life here.
Now, to answer your question.
My sister bought a house recently. She worked closely with this buyer's agent -, and says that he's great. Feel free to ask some more.
Apr 26, 2018 | Cars & Trucks
Are spare parts available in Queensland Australia?
Salzburg is in Austria you know, not Australia?
  • Electric Shaver Repairs in QLD: Gold Coast - StartLocal www.startlocal.com.au > ... > Electric Shaver Repairs Find popular local Electric Shaver Repairs in QLD: Gold Coast at StartLocal®.
  • Electric Shaver Repairs in QLD: Brisbane - StartLocal® www.startlocal.com.au > ... > Electric Shaver Repairs Find popular local Electric Shaver Repairs in QLD: Brisbane at StartLocal®.
  • Braun Household Australia ' Service & Repairs Locator www.braunhousehold.com/en-au/customer-support/service-locator Find Braun Household Australia Service and Repairs Agents using our Service Locator
  • Shavers Electric Repairs in Carindale, QLD 4152 Australia ... www.whereis.com/qld/.../category-shavers----electric----repairs Find directions to local Shavers Electric Repairs in Carindale, QLD 4152 with ease.
  • Shavers Electric Repairs in Queensland, Australia - Melway ... www.street-directory.com.au/qld/shavers-electric-repairs Shavers Electric Repairs in Queensland, Australia - Street-directory.com.au provides Australia Map, Melway, Sydway, Brisway, Ausway, Street Smart, free comprehensive ...
  • About Us - Shaver Shop - Australia https://www.shavershop.com.au/about-us.html About Shaver Shop: Shaver Shop is a specialist personal grooming retailer that has successfully operated in Australia for nearly 30 years. Shaver Shop is a proudly ...
  • Shavers -- Electric -- Repairs in GREATER BRISBANE, QLD ... www.yellowpages.com.au > Shavers -- Electric -- Repairs in QLD Find Shavers -- Electric -- Repairs in GREATER BRISBANE, QLD in Yellow Pages®
  • Shavers electric repairs in Maroochydore, QLD 4558 ... www.yellowpages.com.au > Shavers -- Electric -- Repairs in QLD Find Shavers electric repairs in Maroochydore, QLD 4558 in Yellow Pages®
  • Shavers - Electric - Repairs in BRISBANE (QLD) : AussieWeb ... www.aussieweb.com.au/directory/electric+shavers+repairs/qld/brisbane Looking for Shavers - Electric - Repairs in BRISBANE (QLD)? AussieWeb Local Search can help you find Shavers - Electric - Repairs, or other businesses, in BRISBANE or ...
  • Shaver Foil Shop ' Brisbane Appliance Service Centre shaverfoilshop.com.au braun shavers, braun shaver, shaver ... always contact the service agent to confirm they can repair your particular ... Online Shop Design by MyWork Australia ...
  • http://www.bing.com/search?q=shaver+repairs+Queensland++Australia&qs=n&form=QBRE&pq=shaver+repairs+queensland+australia&sc=0-35&sp=-1&sk=&cvid=576EAF2A239346998D14A24583AA72A8
    Jun 12, 2016 | Health & Beauty
    Where can I buy replacement blade for 580 Huskylock overlocker in Brisbane?
    Look on Ebay!
    Cheers,
    Embroidery Services
    San Diego, CA
    Jun 08, 2016 | Sewing Machines
    Where can I get replacement parts?
    Check with an appliance parts supplier in Brisbane.
    Feb 13, 2016 | Russell Hobbs Blenders
    Hello, I have purchased an LG RH397D DVD Recorder in Brisbane Australia. Eveything works well except that I cannot receive channel 73 (mate) and 90 (Go). I can press guide and the recorder will tell me...
    its simple ,HD stands for "high definition" and either your TV or DVD player cant do HD ,these channels will be only screened in HD ,this is why you cant watch them ,you will need to update one or both of them .THANKS for using FixYa
    Feb 10, 2011 | LG Televison & Video
    I have a Marantz Model 74SR770/02B which needs repair. Preferably a Marantz agent in Western Australia. Help!!
    gidday mate!
    No problem, here is a list of Authorised service centers. I used to be one here in Brisbane for 12 years until 2002. Bit far to send it however.
    If you have any dramas contacting these guys, I ma happy to look into it further for you.
    http://www.marantz.com.au/serviceCentreResults.jsp?page=1113&brand=314&state=2267
    regards
    robotek
    Jul 13, 2008 | Marantz Audio Players & Recorders
    Where do you purchase the dishwasher salt from I recently purchased the AEG favourit and am having problems sourcing the salt....(brisbane area in Queensland Australia)
    if you are in a soft water area then salt is not needed but is essential in a hard water area. normally available from any supermarket
    Jul 10, 2008 | AEG Dishwashers
    51 people viewed this question
     Grubhead
    Grubhead
    Marvin
    Marvin
