Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco Digital Italia Fix
Hello, I have a Digital Italia and yesterday the steam **** popped off.  I called Starbucks and Saeco and they said it was designed to do this if there was a build up of steam.  My questions is this: Is there a way for me to reattach the ****.  I have recently moved to Halifax, Nova Scotia from the states and there are NO repair facilities near me.  It seams like it might be a simple fix but I am not sure.  Any help is greatly appreciated
I had this same issue with my machine and unfortunately I had to send the machine back for repair. The steam knob should pop right back on, if positioned correctly. The people (Starbucks, Saeco) whom you spoke to were correct, that there is build up of steam (or back pressure) it will cause the knob to pop of in these conditions. The root cause of this problem is most likely (as in my case) that you steam wand is clogged. Even if you keep it cleaned externally, there may still be debris that builds up INSIDE the wand. To correct the problem, take some wire (we used decorating craft wire) that will fit into the end of steam wand. Push the wire as far up as you can and continue to move back and forth. Flush the wand either with steam or hot water and repeat several times. I do this every month or so to keep the debris from building up inside the wand. Good luck and I hope this works for you.
Posted on Apr 13, 2008
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
My Saeco Digital Italia stream/hot water wand quit working. When I press stean and turn the knob it pops out (not off) and nothing comes out. Hot water also want come out.
Push in on the knob when it pops out if that works then the steam valve assembly needs to be replaced, ask for the stainless steel valve replacement.
Mar 11, 2011 | Starbucks Saeco Italia Digital Barista...
Starbucks barista machine steam valve leaks.
Hi Sammy,
I think you have to replace the steam valve and the gasket in it.
Best regards
Nov 07, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Digital Italia steam knob
Take off the top and you will see the steam valve, try to mount the parts again.
Best regards
Sep 09, 2008 | Starbucks Saeco Italia Digital Barista...
Digital italia espresso machine
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at :
Jun 28, 2008 | Starbucks Saeco Italia Digital Barista...
Super espresso machine leaking
Your steam manifold needs to be replaced. I still have the original in mine but if you don't cool them down after steaming they will develop hair line cracks and leak after while. To cool it down after steaming push the steam button again, then open the knob and run it till you have a steady stream of water, then close the knob.
The replacement manifolds are black and have held up very well but they have a brass manifold re[placement but you will need new mounting hardware.
Feb 28, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco italia error
What happens when you open the knob on the right? It may just need priming.
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
190 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
