Question about Fuji FinePix A345 Digital Camera
LCD Problem my A345 shows no images except for varying degrees of grey lines. It does not even show the menu options. I cannot take any steps as there is no information.It still takes out good pictures. can u help with this problem.
    Master:
  • 377 Answers
Plan on having extra light sources on hand whenever you shoot digital. It's the nature of this wonderful beast: Digicams just need more light than film to get the job done because film is simply more sensitive to light than the sensor arrays in most digital cameras
Posted on Mar 24, 2008
6ya staff
SOURCE:
How to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Canon PowerShot A640 Digital Camera
How do i formatt a new xd picture card, can't find manuel
Ah .. I did not see, the question falls under a345 .. sorry for the silly question above .. If you see Setup menu options it has following options:
Image display, Power save, Format, Digital Zoom (on/off), Beep, Shutter, LCD, Date/Time, Time Difference, Frame number, USB Mode, Language, Video system, Discharge (for Ni-Mh batteries), Reset.
The third option is Format.
Apr 02, 2009 | Fuji FinePix A345 Digital Camera
LCD SCREEN PROBLEM
hmmm... that may be a problem within the lcd itself. have you tried seeing the pics that you took an look at it on your computer?
msg me if theres anything else....
Mar 11, 2008 | Fuji FinePix A345 Digital Camera
A345 problem
have your phone servied because those gray lines means impending doom..
Jan 25, 2008 | Fuji FinePix A345 Digital Camera
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
Samsung SyncMaster 710N 17" LCD Monitor - Grey screen
Does this unit have an external power supply (wall wart)? If so, substitute a known good one of similar specs. If the original is 12 Volts/1.2 Amps, find a 12-15 Volt/1.2 or greater Amp. DO NOT go over the voltage more than about 15-20%. DO NOT go under the current rating less than 90% for just long enough to see if it works. Be sure the connector fits PERFECTLY!!! Some will appear to fit but will be loose. Do not under any conditions replace a DC supply with an AC one or vice-versa.
Sep 12, 2007 | Samsung SyncMaster 710N 17" LCD Monitor
Lcd screen not working
Yep the percieved advice is not fixable do to cost and the rapip advancement of new models If it is out of warranty - the maker may offer swap out exchange for a reasonable price. Try their website
May 14, 2007 | Fuji FinePix A345 Digital Camera
A345 No Image
Sounds like something as simple as a full memory card or a lens cover fault, apologies if i'm wrong
Dec 13, 2006 | Fuji FinePix A345 Digital Camera
Fuji FinePix A345 Digital Camera Logo
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
