Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic pt 53tw53 rear projection
I have sound but no picture
  • 1 more comment
  • jobrn1 Mar 14, 2008
    made 2004; Ihave sound but faint color running in the middle from top to bottom. We were watching and it just went out suddenly.
  • astamets Jun 21, 2008
    I need to know where the vertical output IC is located so I can get it changed out. I too have sound but no picture.
  • Anonymous Sep 06, 2008
    I HAVE A PANASONIC PT-53TW53G , HAVE SOUND BUT NO PICTURE. CAN I FIX THIS MYSELF?
  • Panasonic Master
  • 8,617 Answers
Check the vertial output IC. either for defective solder or defective IC. This model has a feature if the vertical output IC fails for any reason the picture tubes blank out as a safety issue.Thereby giving no picture but audio still functions.
Posted on Mar 11, 2008
2 Suggested Answers
  • 34 Answers
SOURCE: PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Posted on Oct 12, 2009
Panasonic pt-53tw53 location of my stk chip
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Jan 06, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Whats the right lamp replacement for my Panasonic PT-53WX42F?
Your model doesnt have a lamp. It has three picture tubes instead.
Nov 06, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53 53 in with bad picture
Sounds like you need new convergences ICs. There are two of them in your set sometimes you can get away with just replaceing one of them but I wouldn't recommend it. They are not too expensive are 15.00 each once you replace them you have to get into the service mode and adjust the convergence.
Sep 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PT-53TW53G
Sorry, I dont have a schematic for that model. I believe you can get one at the following link.
http://servicemanuals.vstore.ca/
Jun 21, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53 tnp2a1h046 schematics
Cheap IC's = open resistor
Replace with X 480293 Kit Use IC's from kit to save $$.......T.
Mar 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Problems with Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
sounds like the blue convergence IC is bad.This is quite common in all Projections units about 3 to 4 years old.
Jan 31, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PT-53TW53
Try to read this blog: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Apr 24, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
